I think the 8/8a at the top means its currently supplying 8 of the maximum 8 amps. The 11kmh suggests this as wellThis is a bit of a worry. Using the 8A tail on my UMC. The current setting under the charge limit is 16A!
I agree but the 16A at the bottom suggests that I could set it to 16, 15, 14A, etcI think the 8/8a at the top means its currently supplying 8 of the maximum 8 amps. The 11kmh suggests this as well
I'm not game to touch the current changing button in case it does start drawing 16A.My car defaults to 16a (greyed out) and then sorts itself to 32 as soon as the plug is inserted. Yours doesnt seem to be getting more than 8 though regardless?
Most likely because you show charge in terms of % SOC. I have mine set to range.Interesting also, mine doesn’t show the charge km/hr next to the voltage like yours does. Weird
I haven't had any phantom braking events in a while - but I haven't driven long distance in a much longer while - like most of us in Oz I suspect. I never had much of a phantom braking problem in and around Sydney - probably because there's always other cars in front that factor into the braking equation. Lane keeping across intersections is regularly (and still) getting upset when lines go away. The latest update did reset my ALC preferences though - so perhaps something has changed.Thanks @ZeeDoktor , I was thinking about lane keeping across intersections, phantom braking and automatic lane changes.
No one outside of Beta should notice any difference on AP if they have purchased FSD.The phantom braking is a funny one. A work colleague and myself picked up our M3 SR+ on the same day. He bought FSD, I didn’t. He complained a lot about phantom braking and mentioned it can even brake from shadows. I’ve had nothing like what he mentioned let alone at any shadows.
Cyclists or pedestrians are nightmarish in mine for phantom braking but I keep my foot on the accelerator to avoid it and all is good. Aside from above I rarely get any phantom braking events either.
Same build month though and both MIC so the equipment would be the same regardless I'd expect.No one outside of Beta should notice any difference on AP if they have purchased FSD.
Could be you got a car with no radar and they have radar.
