No. They're actually cooling towers, used for heat rejection from cooling water systems. These ones are made by Evapco, one of the larger international brands and the same ones used in a similar quantity at Austin. These units are in two halves with the fan section in the foreground placed on the bottom and the evaporative media sections at the rear placed on top. I expect most of these will be installed on the upper level of the new battery building (shown on the plans) but they could also go in the central thermal plant building next to the big tanks (where the video screenshot above is).Looking at Tobias Lindh's GigaBerlin video and there is some new equipment at the site. I am guessing theses are hoppers for cathode/annode material in the cell manufacturing plant. Can anyone confirm if that is reasonable.
If so, the quantity is impressive - I didn't see anything like this from the Kato Rd flyovers.
No. They're actually cooling towers, used for heat rejection from cooling water systems. These ones are made by Evapco, one of the larger international brands and the same ones used in a similar quantity at Austin. These units are in two halves with the fan section in the foreground placed on the bottom and the evaporative media sections at the rear placed on top. I expect most of these will be installed on the upper level of the new battery building but they could also go in the central thermal plant building next to the big tanks (where the video screenshot above is).
If you look at Jeff Roberts most recent Austin video (see below) you will see footage of the two halves of these cooling towers being lowered into position on the upper NW corner of the battery plant area. Kato Rd has slightly different cooling towers along the back plantroom strip on the main building but you only see the top part.
Here are some Important material science differences between Tesla and Mach E coolant hoses left out from the Sandy Munro’s YouTube video, as tweeted by Alex Lim:
I'm developing material for those coolant hose and I have some hints to share:
i) the rubber hoses in Mach-E are traditional rubber and can't be recycled easily because it's vulcanized with sulphur
ii) rubber hoses are very heavy (0.2-0.4 lb/ft, depends on diameter)
iii) rubber hoses requires high energy input to manufacture, less flexible for fitting into tight space, but material cost is low
iv) Tesla uses nylon material for tubing, which is a thermoplastic that's recyclable and more energy efficient to produce
v) nylon tubings are more flexible, very lightweight (0.06-0.08 lb/ft, depends on diameter), material cost is however 3-4 times more expensive than rubber
Good point. Even if the raw material cost is 3X more for nylon but the since nylon hoses are lighter, and lengths are 3X shorter for Tesla, actual cost to Tesla per car for hoses should be less than for Ford.Is the price difference per kilogram? Or per meter?
They did that here (DFW) for a while, but all the tickets were thrown out in court, so they stopped doing it.You're lucky then, Here we have red light revenue systems and they change the yellow light time to the minimum legally allowed if there is a camera and leave the yellow light time longer on other lights that have no camera even on the same street.
Very easy here to see people running red lights when you have no consistency on when a light will turn red.
Pretty sure that all current US cars come with Autopilot only. Enhanced autopilot (EAP) is defunct as per the Electrek article here.Mod note: My understanding is that all current Tesla models in the US come with Enhanced Autopilot as standard, therefore the cost to subscribe to FSD is only 99$/month. Much of the discussion here seems to assume 199$/month. Please stop such discussion until/unless this is clarified. I'm in an airport, so can't do it at the moment. --ggr.
I'm not sure what clarification you're looking for but I don't believe your assumption here is correct @ggr - but anyone feel free to correct me.Mod note: My understanding is that all current Tesla models in the US come with Enhanced Autopilot as standard, therefore the cost to subscribe to FSD is only 99$/month. Much of the discussion here seems to assume 199$/month. Please stop such discussion until/unless this is clarified. I'm in an airport, so can't do it at the moment. --ggr.
I would love to know the numbers, and it might be good in the short term for the stock...but actually if I was Elon I would say nothing. Why should he? a short term bump in the stock benefits long term investors & elon not one bit. In fact all this would do is hand over information to the competition, perhaps encouraging them to work harder on better software. Why do this?It will be interesting to see if Tesla releases any numbers on Monday for FSD subs .
True, but... Starlink is already completing at least two contracts with "telco's". Those contracts have been disclosed with 'backhaul' services the openly discussed part. Not openly discussed but also included seems to be arrangements for cellular connections for Tesla vehicles. Elon has discussed '5G support' as part of 'telco' discussions.1, how many times does Elon have to say that Teslas WILL NOT have Starlink as you have to have a pizza box sized antenna mounted on the car? Every time someone brings it up he shoots it down, period.
2, stop having daydreams about getting Starlink / SpaceX shares for free. If it IPOs it will do so to get EXTRA capital into "Musk Enterprises" to fuel rapid growth, not to move $ around between his companies. He said he will try to do something for TSLA longs to get first dibs on the IPO, but never said anything about free shares.
Your second point is certainly valid.1, how many times does Elon have to say that Teslas WILL NOT have Starlink as you have to have a pizza box sized antenna mounted on the car? Every time someone brings it up he shoots it down, period.
Since I can edit my post. People the Model S Long Range has the same trap speed as the Porsche Taycan Turbo S in the 1/4th mile. It cost 85k with double the range and it charge faster without an 800V architecture and a useless two speed transmission at $100k less with the Taycan Turbo starting at $185k. It can actually seat 5 people with a tons of cargo space.
Best run was 10.869 at 129.675mph with. A crappy 1.854 60' at 85% SOC and still trapping 127.68 at 70% SOC. I hope Tesla let's the car launch harder of the line.
