If this is indeed the same V4 that will come to the US it’s a bit disappointing to Cybertruck charging times
And we had some leaks in the past suggesting that it would be 350 kW only, so seems credible
Instead of the sub 20 minutes 10-80% we are looking at more likely 30+ minutes for the 500 miles version, I can plug all that in my calculations later for a more precise number
Won’t be bad bad, but far from leading both in range added per minute and % added per minute
For the towing folks around 20 minutes would be really nice, 200 miles fully loaded 10-80% and sub 20 min charge stops
But it will likely have a quite flat charging curve, likely to hold 350 kW up to 50% or even a bit more on the biggest battery version
