I didn't point that out, but I noticed that too when I read it... but then I thought, "Is it bad that I know what they mean?"
I guess that means I'm a certified geek then, because I'm fluent in Hex. :tongue:
Ha, ha: Floor it much?I have a lot of "green" at the top of the graph!
Yes, this happens with some VehicleLogs. One or two out of the seven that I have pulled from my car do this, one error or another. It's an undocumented file format, so there's no easy way to anticipate every possible data pattern.I get the following error:
Vehicle Log file format parsing error.
Bad Checksum
I just click ok and it seems to work after that.
Try running the application first, and then use the File > Open dialog to select the file. That's what I use. Plus, I mostly use the File History to re-open log files that I've already seen.I, so far, haven't been able to get it to work at all with Lion. (won't let me drag the file to import.)
