scottf200
This is my son's TM3. He drives about 110 miles / day. After looking at TeslaFI data he averages 40% battery usage. Use to charge to 75% (so down to 35%) and lately charges to 80% (so down to 40%). Actually I created an End_of_Day SOC chart for a little better accuracy but I started all the SOC Begin_of_Day using 80% but it still gives the gist even if off by 5%.
I realize you have a theory about not regularly going down to 20%. He does do that on road trips 2-4 times per year.
It is unclear what additional columns you are looking for in the 'All' tab. I don't have that. Here is the 'Battery' tab. NOTE: this is from last weekend when he charged to 100% right before doing some weekend errands. I have other charts showing the 100% charge lasted for 48 minutes until amps stopped flowing (ie. stopped charging).
<snip>
Blue is Calculated 100% range.
Green is Firmware at the week but not release level (yyyy-wk-rlse).
Purple is the temp (F) plus 200 to scale it for the left Y axis.
2019.40.2.1 (aka 2019.777) seemed to be the biggest timing of the 100% range dropping.
The new TeslaFI . COM reporting feature shows this as well. NOTE: that it only shows 80%+ charges and my son use to do a lot of 75% charges.
https://i.imgur.com/6WfHkst.jpg
The report is awkward to get to (locate).
1) Menu: Fleet, then 'Software Tracker'
2) then In the 'Software Version / Count / Percent' section click on the hyperlink for the version in question ... ie. 2020.4.1
3) then do a find for 'Your' or similar to get this type of line ' *Your Vehicle* 2020.01.30 22:09 '
4) then click the 'View' hyperlink.
Maybe there is another way but I have yet to find it. I had to stumble across '3)' above.
