Realistically anything outside of a 1/4 mile radius should be considered travel charges. That would also compensate for any GPS discrepancy around your actual home. (I say this only as I work about 3/4 of a mile from my home.)I had originally set things up to consider home charges anything within 1 mile of your home address. I just changed it to .5 miles and it looks like it's showing those as travel charges. I'll see how the .5 works out and can always adjust or put it as a user editable variable as well. .5 is still probably overkill.
I charge both at home and at work, I'd rather like to have charging totals / "money" for both (separately from Travel Charges)
For some reason my Home charges shows zero for October. Image below includes one of the home charges.
Also not sure how the monthly Efficiency %age calculates?
I fixed your home charge issue. When you sign up I use a google api based on address entered to get the lat/long. Sometimes it's not very accurate so I had considered a home charge within 1 mile of those coordinates. A few posts up I had changed it to .5 miles which broke it for you. I manually edited your home lat/long and now it appears to be correct.I charge both at home and at work, I'd rather like to have charging totals / "money" for both (separately from Travel Charges)
Yes, I'll be working on the headers soon and will add that or give options to show what fields you want displayed.@Jdeck - in the "Raw Data" tab is it possible to add SOC next to "battery_range"? Also what is rear_seat_type field and how do people use that? Finally, are the max and min_avail_temp in centigrade? Can it be shown or toggled in Fahrenheit?
After a quick look I found a problem with the typical range loss additions for the month. It looks like your monthly efficiency is displaying a much more appropriate % now. I'll look into it in more depth tonight to make sure it's correct.I charge both at home and at work, I'd rather like to have charging totals / "money" for both (separately from Travel Charges)
your efficiency at 92% seems pretty on par
Charges, sleeps and idles should now be displaying Typical range for appropriate cars. Let me know if I missed anything or messed anything up. Thanks.Hi, @Jdeck , I think you still remember the Starting and Ending Ranges are not calculated correctly for JP and possibly EU cars. See attached ; my typical range left at the time of screenshot was approx 368km.View attachment 201171
Looks perfect to me!Charges, sleeps and idles should now be displaying Typical range for appropriate cars. Let me know if I missed anything or messed anything up. Thanks.
I have a question regarding the ODO data on the charge item.
In my case it shows 5'560.98 on the charge item and on the trip item I got ODO 8'997.72 (km).
What this number (5'560.98) represents ?
When charging, which number is the "purchased electricity": kWh used or kWh Added or sum of both ?
Thanks in advance for your advise.
BTW you have done a great job with this application
Very minor (but probably very low LOE) request: is it possible to add a music icon to the list of frequently visited places?
I go to a music studio once or twice a week to practice with my band, and it would be nice to see the icon at a glance.
Thanks James!
I recently added the odometer to the charge table per a couple requests and forgot to add the conversion to km. That should be corrected now.
The charging cost is based on the kWh used.
Thanks!
