I wonder if the new 70 and 90 packs are the BF's with Silicon?
Finally, on Flathill I agree with the other posters - tone it down bud. On the other hand, I understand his frustration. This thread has been a good example of a failure in this forum (not due to the mods) - We have posters like ... MukeBur who clearly have nothing substantial to add continuing to post - while wk has been driven from the thread, and he is one of the few who SHOULD continue to contribute.
- - - Updated - - -
This post is a perfect example of why the technical minded, wk, myself, other... will always be driven from further posting - and threads that have the potential to make sound technical conclusions will continue to be rare on this forum.
The other speculation is they are GAs which have slightly higher capacity than the BFs.I wonder if the new 70 and 90 packs are the BF's with Silicon?
Oh yeah and in his free time he reverse engineered the CAN busses used by tesla so he could read the actual brick voltages, pack currents, motor torque and power, and all the diagnostic screen info, and described how all that was done in another thread.
Like i said it's difficult to keep up, but he has plenty of validity and credibility amoung the technical crowd. His knowledge, skills and abilities have been demonstrated numerous times--nobody practiced in the art of electrical engineering would doubt his results.
No, just done having to defend my data and conclusions against people with no credibility. .........................
Again, the data speaks for itself. I've logs from over 20 cars, from brand new to a signature VIN S00XXX. Not a single one shows pack capacity at or even close to 85 kWh as reported by the car itself. Data which matches my own testing of cells outside the car, and the tests of others.
I don't care what Tesla does with the cells prior to delivering them to customers, or not. If the product I received doesn't meet spec, then it doesn't meet spec. Plain and simple. People are welcome to verify this for themselves, and I invite them to do so. I've outlined the relevant BMS CAN messages here.
This was obviously my attempt to show that the capacity difference was significant, using a monetary value derived from Tesla's own pricing, for folks who may or may not have understood the delta.
I could care less about the implications of what the data tells. The data says that customers never received a pack that Tesla labeled "85 kWh" that could actually be charged to 85 kWh in or out of the vehicle. That's a fact based on mountains of data, including admission of the cars themselves.
If the data said that the pack was say an 86 kWh pack (it does not) we wouldn't be having this conversation, and people would be praising Tesla for under promising on the spec and everyone would be happy. Instead it's data that shows that the spec doesn't match the advertised spec, however little the delta, and for whatever reason that triggers half of the forum to jump on the dog pile with the messenger at the bottom.
Fun that we have conflicting data, though. However, Tesla's BMS does in fact agree with mine pretty much exactly... so, not sure where that leaves us. Edit: Added data point being that I collect mountains of charge/discharge data from my ~16000 cells in my solar setup, and they also match nicely with my other data extrapolated out to the large scale full pack. I've not discharged my solar pack down to nothing, but I have charged it to 100% several time, and have discharged it on a few occasions below the voltage Tesla considers 0%... and the data still matches up with my single cell testing.
Possible. Elon did mention that they started using a bit of silicon in the anode when introducing the 90 kWh packs last July.
My read of this thread:
1. Measuring cell capacity is a non trivial measurement.
2. If a Model S were driven continuously on a flat road in warm, sunny weather, with a max power output of 5 kW, then perhaps it *might* be possible to get something around 85 kWh.
3. On the other hand, if the S is driven in everyday conditions the pack is more like 81 kWh with 77 kWh available to the driver. This statement is supported by data straight from Tesla's own BMS, something a lot of folks are overlooking, IMO.
Doubtful since the BF has the same Wh capacity as the B.
You bought a car, not a truckload of cells.
Isn't that exactly the problem? Whilst the total capacity of the individual cells may add up to somewhere around 85kWh, we didn't buy a truckload of cells we bought a car, and the car as a whole only has 81kWh (as reported by its own systems).
Correct. The 90 pack is mostly likely NCR18650GA's which do have silicone nano particles in the anode.
The 70 pack (at least the one we just pulled apart) is the same old BE's - 14 full modules - so rated capacity of about 74 kWh. if you use 85*14/16.
Isn't that exactly the problem? Whilst the total capacity of the individual cells may add up to somewhere around 85kWh, we didn't buy a truckload of cells. We bought a car, and the car as a whole only has 81kWh (as reported by its own systems).
... - we went ahead and pulled apart the 70D. We pulled the pack apart and it does have 14 full modules. ... The 70 pack (at least the one we just pulled apart) is the same old BE's - 14 full modules - so rated capacity of about 74 kWh. if you use 85*14/16.
That is what's being disputed by some people in this thread.The new cell capacity rating is 85KWh, that's how Tesla rated it.
The number that the car's internal system reports, the first time it's charged to 100% at the factory after being assembled, rounded down to a nice round number. If say all cars have approximately 81kWh capacity, maybe plus or minus 0.x kWh due to variance, then round it down to 80.How would you rate the battery then?
No, so it looks better against the 60/70/70D.What possible reason would Tesla have to try and deceive people that their 85KW battery was really only newly rated at 81KW?!?! So it looks much better against the competition like the BMW i8 with its massive 7.1KW battery??
This thread has merit precisely because the cell specifications are not publicly available. If they were, we wouldn't need to rely on testing by forum members.Show me a reference that the exact cells Tesla uses are RATED by the manufacturer at a value such that the pack makes less than 85KWh. Then this discussion will have some merit.
Makes sense that they just filled in the empty spaces in the 60 to get the 70 instead of using the newer cell chemistry. Sounds as if the 70 will have close to 70 actual, just as the 60 had slightly over 60 actual. (I'm using "actual" to differentiate from manufacturer cell rating). Very interested to see what the 90 has and what the cells turn out to be.
The new cell capacity rating is 85KWh, that's how Tesla rated it. How would you rate the battery then? 81KWh because after the first few months they test at 81KWh? What about after a year? It will be less. Will those owners be entitled to whine that their P81D only has 80KWh now and should be rebadged a P80D? Maybe you are suggesting that each car should be tested at time of sale and badged based on the exact capacity at that time, maybe a P82.5D. How about a LED digital display for the badge that could test the battery every day and display it on the side, maybe P82.123D??
All these arguments show how silly the whining on this thread is.
Let go through it, What was I told and what did I get?:
A battery rated at 85KWh, got that
An EPA range of 265, got that
What possible reason would Tesla have to try and deceive people that their 85KW battery was really only newly rated at 81KW?!?! So it looks much better against the competition like the BMW i8 with its massive 7.1KW battery?? (which would probably only test to 6.5KW with an amateur testing it) While the battery testing is interesting, It really has nothing to do with the new cell rating specification which the battery rating is based on. Show me a reference that the exact cells Tesla uses are RATED by the manufacturer at a value such that the pack makes less than 85KWh. Then this discussion will have some merit.
It just boggles me how people contentiously fail to understand.
There are new cells and there are aged cells - calendar life.
There are uncycled cells and there are cycled cells - cycle life.
There is "high-C" discharge and there is "low-C" discharge - power profile.
There is continous discharge and there is intermittent discharge profile - power profile.
There is temperature and there is production variation - life.
Is it BF, BE or it isn't... years ago it was established that chemically, those cells are similar to what panasonic sells to general market. What those cells lack is internal protection as it is supplemented by pack services. This affects cell weight and thus cell energy density. And they probably have some additive that helps prolong performance after years of usage.
It is dead easy to measure, and kid can do it. It is hard to understand the measurements, implications and circumstances that affected them.
Anyone who feels the need to call someone apologist, fanboy has already failed in understanding.
Repeatedly demonstrated agenda of the OP is evident, one google search away.
"I didn't receive what I pay for" is pure BS. You bought a car, not a truckload of cells.
Like wk, I see how pointless it is to continue in this thread....
I will add this - we went ahead and pulled apart the 70D. We pulled the pack apart and it does have 14 full modules. So the pack is ~74.37kWh per Tesla's original rating.
I will have another fun post in a new topic soon
- - - Updated - - -
Sure there are people who bought the car just to tear out the cells and build stationary storage out of them.This is very short sighted. Not everyone is like you. There are legitimate people who bought the car for the specs as well as the car.
Did anyone disassembled a tesla cell and compared physical internals with off-the-shelf cells?The 90 pack is mostly likely NCR18650GA's
