buddhra
For reference, here's the outer diameter of my nut driver, which is pretty much the same as the hole above the shock assembly. It's likely intended to be 17.5mm.
I grabbed the thinnest socket I could and took it to a wheel grinder. Even .5mm will help with the removal of the three top nuts.I can confirm the 13mm from Amazon (as posted above by buddhra) does fit through the hole. It is very snug and almost zero wiggle room. The problem is that if the nut below is not perfectly lined up, there is not enough wiggle room for the socket to line up with the nut. On my car, only 1 of the 3 nuts could be removed. If you are lucky maybe all the nuts will be lined up.
My advice to all is not to buy this socket until you've removed the frunk liner and checked your car to ensure the alignment. Even 0.5mm will be a problem. For me I had to remove the 4 outer bolts and take out the entire a-arm mechanism. This is definitely a bit more work but you may have no choice.
I think you can loosen those four 4 bolts, and wiggle the the control arm mount enough to line up those 3 bolts. Not ideal, but less hassle than taking the whole thing out.I can confirm the 13mm from Amazon (as posted above by buddhra) does fit through the hole. It is very snug and almost zero wiggle room. The problem is that if the nut below is not perfectly lined up, there is not enough wiggle room for the socket to line up with the nut. On my car, only 1 of the 3 nuts could be removed. If you are lucky maybe all the nuts will be lined up.
Other than the recommendations above for aligning the holes, anyone else have a source for these thin 13mm sockets or has a spare one they want to sell (may be a single use thing)? Thx in advance.
Dude, that’s so awesome. Thx!If you’re willing to pay for shipping, I’ll send the one I used. PM me.
Guess you’ve not purchased much in professional tools $35 is somewhat of a bargain for a specific use like this.Great idea but it is a bit pricey especially after shipping unless it's repeatedly used.
*cries into SnapOn toolbox*Guess you’ve not purchased much in professional tools $35 is somewhat of a bargain for a specific use like this.
Yep, And my Park toolbox. But quality tools are worth shedding a few tears. Buy once cry once.*cries into SnapOn toolbox*
This definitely looks like a useful socket for those working on Model 3 front suspensions but being that a 13mm socket (albeit not extra thin-walled) from SnapOn is $25, I felt $35 plus about $10 shipping was a bit pricey and I'm taking a wild guess the SnapOn is of higher quality. I'm not saying I wouldn't buy it or that it's not worth the money but all I was saying is that it is expensive. Personally, I have some very cheap tools and some others that are pricey as well.Guess you’ve not purchased much in professional tools $35 is somewhat of a bargain for a specific use like this.
