For one, S and X are safer than Model 3.
Not true. The 3 is actually safer than S and X.
Model 3 achieves the lowest probability of injury of any vehicle ever tested by NHTSA
The S is a much more attractive and expensive looking car than the 3. For what it costs it needs to have those characteristics.
Only under conditions tested. S and X, being heavier are safer overall.
If you look you can find Musks quote about as well.
The wiring of these two cars are not rated the same for the max safe amperage. We are talking about the Model S onboard charge cabling of 17 mm in diameter and rated @350 amp vs. the heavier Model 3 onboard charge cabling of 20 mm in diameter and rated above 500 amp or so. The model S is an older car with older HW. The Model S refresh will catch up.
AFAIK the MS internal cabling is made of copper though, as opposed to aluminium in the M3, a material with 58% higher resistivity, which would explain the thicker cables to take the same current load.
If M3 nominal pack = 400V = same as 100D pack
250kW/400V = 625A
Then, taking your cable diameters to be accurate:
ø20mm = 314mm^2 of aluminium rated for 625A = 1.99A/mm^2
ø17mm = 227mm^2 of copper, at 625A = 2.75A/mm^2
= a mere 38% increase in current density, i.e. should be easily handled by the lower resistivity copper.
However, if the newer 18650 cells are (as I suspect) essentially the same chemistry as M3 21700 then the charging bottleneck in MS is likely to be the battery cooling system itself, which with one continuous ribbon is less efficient than the M3 with several parallel coolant flows. Nevertheless am hopeful to see a v3 SuC max rate of 185kW for 0..55% SoC for 100D pack, which would still be a fantastic boost roughly halving the typical charge time to 80%!
Even on v2 SuC, if the charging profile with pre-warming holds at 145kW for 0..60% SoC, that should probably cut 25% off the 10..80% charge time, i.e. reducing it by ~12min to 33min, which will be great already!
I suspect many of the Model 3 upgrades are bug fixes. Model X has been out, so fewer bug fixes.I love my Model X but I feel like Tesla has let me down. Specifically, in the realm of software updates. We're nearly four months into 2019 and the Model 3 owners are getting updates weekly it seems, and my Model X is still sitting on 2018.50.7.
I guess that's true to an extent.... but where is Dog Mode? Sentry Mode?I suspect many of the Model 3 upgrades are bug fixes. Model X has been out, so fewer bug fixes.
Great maths! Thanks. What do you think about the 75 pack in this case? It should benefit some as well.
Yes we can take advantage of the v3 charger when the software update rolls out. Yes we will get faster charging as a result. The battery preconditioning will work with S and X while you are driving to a charger which gives us some additional charging speed. What was never made clear is what the max charging speed is of the S or X and can that be increased in the future with a software upgrade. Yes they highlighted charging speed for the 3 which means 3's charge faster and get in and out quicker helping reduce congestion but it is still unclear what the max charging speed of the S and X are.Charge? Yes. Charge @ 250 kW? No.
The Model S refresh is gonna have to be that serious of an upgrade, since the Taycan is coming. Tesla is gonna need a significant differentiator to draw all those Porsche Audi Jaguar buyers that are jumping ship , and to draw new blood. After self driving, battery efficiency of the Competition evolves , and the charging networks are up for everyone else via Electrify America, and Charge point. What reasons would we buy a Tesla ...besides we like the brand?And let me just add that knowing Tesla, when they do finally do a refresh of the Model S, it will probably be a wowzer of a refresh. It could include better batteries for ranges close to 400 miles, a super slick new interior, increased performance, additional hardware for FSD, plus some other goodies I have not thought about. We are all going to drool with envy when we see the new Model S. Trust me!
Only 2.5 and some 2.0 cars are getting updates.Dog mode is here for S/X but sentry is not.
The other brands don't have a fast-charging network already in place. That gives Tesla a big advantage, at least for the next year.
Take a look at what you have to do to start charging on those connectors (North America only). There are about ten steps. It will be five minutes before the charging starts, maybe longer in those places where you have to go inside to get a code to type in.The other brands don't have a fast-charging network already in place. That gives Tesla a big advantage, at least for the next year.
