Since this little conversation about how long does it take to operate EV charging in cold climates has confused some people, I'll do my best to explain to anyone else who is still interested.
If nothing else, take as a bit more input on the challenges (and fun too!) of operating an EV in colder climates. It is not to be taken too seriously. EV driving is fun and winter too.
In short, the point was: If you have to do your daily EV charge, at home and at work, outside in the freezing cold perhaps with snow, you may be tempted to forgo plugging in (and indirectly increase your chances of range anxiety), because it is unpleasant and takes a bit of time depending on weather conditions affecting things, operating the charger and so on. If you drive into a warm garage at home and/or at other daily location, this will not affect you.
It stated with this message bessage from 3s-a-charm:
Funny I was just thinking that yesterday... and I don't even have my Tesla yet! Was driving my ICE and getting a feeling of aggravation looking at the needle reaching "E" and thinking I have to stop somewhere for gas and it's cold outside and I'm in my suit and I just don't want to! Then I realized I have "reverse range anxiety".
His point was, as I read it anyway, that cold weather affects our willingness to go outside and fill up the gas tank, something he coined the term "reverse range anxiety" for. To which I replied offering that "reverse range anxiety" can affect EVs too, perhaps even more often than an ICE (because you need to charge more often and also because cold affects battery life), if one doesn't have warm charging areas:
I hope you have warm garages at home and at work to charge in, though, because with an EV you would be "gassing up" in the cold twice a day or so.
Similar "it's too cold" does reduce the chance of plugging in.
I thought my message was self-exlanatory and innocent enough, didn't really expect it to elicit any kind of response. I still think it is merely a simple statement of fact. In the cold, running into the warm and not plugging in can be tempting (because it also means you don't have to plug out in the morning and clean a cable from snow etc.), but I also offered that if 3s-a-charm lives in an area and a situation where he doesn't have to charge in the cold often, then of course this is not an issue for him/her.
My message received this comment:
For goodness sake, plugging in to a public charger takes less than 20 seconds to wave the card, plug in the adapter, then plug it into the car.
To which I answered with
a message, starting with the words "My experience is different.", explaining my experience why charging in the cold can take several minutes to operate (depeding on ice/snow covering/locking charger port/trunk/frunk/charger, running/wrapping up/cleaning cable from snow, operating a charger that may require fiddling with controls), if you have to provide your own cable. I followed up with a clean test, at a free charger, free of snow and ice, that a minute and a half is a best-case scenario of plugging in and plugging out - and then more if there is detrimental weather, operating a charger or charging issues (having to re-plug, unlock connections to do so etc.) hampering it.
Not a single person has offered any point as to what in my measurements or rationale is wrong, so it is very hard to know what exactly people are disagreeing with. There has been more talk about the length of my comments than the merits of my arguments. I certainly couldn't charge an EV in 10-20 seconds, going to the trunk to pick up the cable alone takes that much times. When one is operating a gas tank, nothing needs to be fetched from the trunk. Now, as I said, operating a supercharger is faster of course.
I certainly meant no offense to anyone, I simply offered two opinions 1) charging an EV - when the cable isn't readily hanging in the charger - takes more time than some people seem to think and 2) in cold weather, "reverse range anxiety" can affect EV operation too, because it is tempting to forgo messing with the cables and charging in ice and snow, if one has to operate them outside. I also said charging an EV in the cold takes a comparable time to filling up an ICE, but I didn't mean it takes exactly the same time - I simply meant a significant-enough time for "reverse range anxiety" to be possible.
Not all people find filling up an ICE in the cold troublesome at all, so the basic issue of course wouldn't affect all people in the first place. But if it does, then they may find EVs having a similar issue.
Fair enough?
Didn't mean to elicit a 50 line post from an offhand comment about the ease of charging at a public station but I stand by the original comment. It's fast and easy. You can disagree and I won't take it personally but I've lost count of the number of times I've plugged into a public charger (cable provided) during Northeast US winters. I wave my card at the machine, plug in the adapter and plug into the car.
I assume from your comments you charge at home in a garage? Because that certainly makes a large difference and my original message clearly stated I didn't consider this a problem for garage users. But if you only have the option of going straight in to the warm or plugging in/out out in the elements daily, going straight in can be tempting because then there is no fiddling with the cable - nor fiddling with it again in the morning - in the cold, perhaps when snow/ice is covering/hampering access to the car, the charger, the cable etc. It is unpleasant as it is, removing charging hassle from it can be tempting. This may be offset by the fact that in some cold areas people may be used to plugging in ICE cars to heaters.
The 1 minute 30 seconds, roughly as a ballpark, test of plugging in and out at a public charger was - I would say - an optimal result (excepting acrobatics to shave off seconds). An outside home charging socket might not be so easy and well-lit to plug into either. That's how long it takes if you need to get a cable from the trunk and run it. I don't see how anyone can disagree with that beyond questioning my measurement. I explained my test in detail for anyone to repeat. It is logical if there are any issues, or if the charger requires operating, more time will be needed. And unlike a gas station visit, charging an EV is an almost daily occurrence or perhaps even several times a day occurrence.
And you are using slow public charging with 200+ mile range that isn't a Supercharger often? So it takes a minute and 19 seconds give or take. It takes that long to walk into the store from where you parked. It certainly takes longer to fill up a gas tank in the cold.
The point wasn't exactly to compare EV charging and filling up a gas tank time, but to flesh out my views that EV charging take long enough for "reverese range anxiety" to happen (causing range anxiety indirectly because filling up is unpleasant due to weather). I agree 1 min 30 sec, that optimal situation at that public charger, wouldn't likely be an issue - but then it was a well-lit garage (cold but still), it becomes a bit different when you are talking of someones yard and inches of snow and ice.
There are no Tesla compatible DC chargers, superchargers included, within my daily area so I can't test. All the chargers I use regularly require me to provide my own cable and that process I measured at 1 min 30 sec total, optimal circumstances. No way could I charge anywhere in 10-20 seconds, but as I've offered all along, certainly 20 seconds to plug-in (and maybe another 20 seconds to plug-out) sounds possible at a free charger where the cable is hanging readily there, like at a supercharger, if the charge port isn't frozen shut and if there are no issues with the charge starting. My measurement was a minute and a half to plug-in, plug-out at a free charger when one needs to fetch their own cable from/to the trunk, when no snow/ice was hampering the process and nothing was needed to operate the chager (no payment, no sending SMS, no setting a timer etc.).
I agree with you (although I no longer suffer winters), most of the time it takes 10 or 20 secs at most. It's also fair to note that maybe in Europe they're not as standardized as we are here and sooner or later European owners are going to cross a border or two and find themselves with different plugs, EVSEs and processes.
Less superchargers certainly is a part of it, because they are faster to operate. I guess 20 seconds could be possible on a supercharger, and another 20 seconds to remove, same with a HPWC in a garage. Beyond that I would say standardization has less to do with my comment, though. The public charger I measured was a free, no operation required charger for which Tesla provides a cable (it charges about 150 km per hour). The baseline seems to be a minute and a half of operation in the cold but clean (a cold garage in this case), when one needs to hook in and out their own cable, provided there are no issues in the charge starting or unlocking.
If there are issues, or if the charger needs operating, or if weather is detrimental it all can take quite a bit more. The warmth of the inside can be mighty tempting...
- - - Updated - - -
Yes, I've had range anxiety ... before I owned an EV. I guess if people want to make a big deal out of this, they will - but I have to agree that I've found road trips simple and not particularly stressful. I'd hazard a guess that the responses we see here correlate closely to how people react to things in general.
I would add to that, they probably also correlate more to the maturity of the EV infrastructure within their area. There is a huge difference in an international audience such as this, regarding that.
