I think having a small buffer at 0% displayed SOC or 0 rated range makes sense. The issue is how the rated range is being calculated as you're driving. If you drive within the EPA assumptions (290 Wh/m for an 85D), the distance you're actually traveling should match the rated range. In other words, if I have 260 miles displayed and I drive 20 miles (within EPA assumptions), I should be seeing 240 miles remaining, which is not the case. Instead, you'll see something less like 230 miles remaining. It's basically decrementing faster than you're actually driving, which is misleading.
Yeah, it all seems to make sense to me. I just think this idea floating around that the 4 kWh buffer we're seeing is the "anti-brick buffer" is incorrect. That would mean folks are able to utilize the anti-bricking buffer which would make absolutely no sense; we would see a lot of bricked batteries I'm sure. It would make more sense the anti-brick buffer is to remain well above the levels where you would brick the batteries, and it does seem Tesla's will shut down around 3.0V, well above 2.5V where it appears lithium-ions will become bricks. There's several videos on YouTube showing folks driving beyond 0% displayed SOC and 0 displayed rated range. Here's
one, here's
another, and yet
another, not to mention you've also proven this as well as several other members on this forum. Here's a
video where someone actually was monitoring the BMS data using TM-Spy past 0% displayed SOC until the BMS reported SOC was 0%. Sure enough, it was on the verge of shutting down at 0% BMS reported SOC (0.0 kWh remaining), and the cells were right around 3.0V.
The interesting part is
@wk057 CAN Bus deciphering PDF has a statement about the BMS reported energyBuffer value that says, "energyBuffer appears to be the antibrick buffer. This is NOT a below 0miles remaining value." Perhaps that energyBuffer value being reported is the no kidding anti-brick buffer, but it seems like there is another buffer that is also 4 kWh that exists at 0% displayed SOC or 0 displayed rated range, or perhaps that is what the energyBuffer actually is and the anti-bricking buffer value isn't even reported? All speculation obviously but perhaps
@wk057 could provide more insight.
Interesting stuff for sure. I think the big take away for me is:
- Displayed rated range is how much you can drive under the EPA assumptions before the vehicle will completely shut down.
- Displayed rated range is misleading since it will decrement faster than how much you've actually driven, based on it trying to achieve a ~4 kWh buffer at 0% displayed SOC or 0 displayed rated range.
Not really an issue for me as I don't like to get much below 20%, but just informative on better understanding the numbers the car is displaying to me.
Edit:
@lymex2018 mentions this in a
post in the Scan My Tesla thread.
