I'm planning on rotating my tires for the first time this weekend. I've never had to rotate tires without having a spare to use, so please tell me if this is a workable strategy. I plan on moving rears forward, and fronts back and across to the other side. I also know the proper method for removing tires (ie, loosen bolts before jacking up, use wheel chocks to prevent car from falling off the jack, etc) so I will not go into that much detail.
I currently have one low-profile jack, two jack stands, and 4 jack pads.
- Jack up rear drivers side.
- Place jack stand under front drivers side and remove jack.
- Remove front drivers side wheel.
- Jack up rear passengers side and swap wheels.
- Move jack to front passenger side and swap wheels.
- Move jack to rear drivers side swap wheels.
- Put last wheel on front drivers side, jack up rear passenger side enough to remove jack stand.
