HankLloydRight
No Roads
That's typical of a failing bulb.
And that's what I would also assume, but that thread specifically talks about the right headlight failing due to the broken ground.
Checked all those . Nothing wrong there . But will check all grounding to be shure .There's a fuse on top of 12v battery.
Checking all the fuses that protect electrical components with a multimeter could help.
Update: there's a ground on both sides.The drivers side ground stud in my model S decided to give it up yesterday while making a turn at an intersection. Not a fun experience!!! I immediately lost all power steering as well lost 95% of my braking power. For me to slow down the car I needed all my weight on the brake pedal, not fun. Immediately had about 8 or 10 different error messages on the screen as well as a whole bunch of icons light up. Also had no drivers side headlight. Luckily I was only 2 blocks from home so I circled the block and drove home. As soon as I got home and put it in park that was it, no more putting it into gear. The car was not drivable at this point.
Lucky for me I immediately suspected the drivers side ground stud because of my previous experience with the passenger side one breaking. I pulled out the frunk and to my surprise the drivers stud was intact and only minor corrosion. It was also very secure. I removed the nut and disconnected the ground wires. I cleaned them up and the ground stud actually looked pretty good. I hooked up the wires and put the nut back on but as soon as I started to tighten it the stud snapped off. It must have been on the brink of breaking due to corrosion even though it looked good.
I drilled it out and installed a new 1/4-20 stud and hooked everything back up and all is now good again.
Learned a lesson when looking at the old stud as looks can be deceiving.
If you end up fixing one of these ground studs go ahead and do the other one at the same time.
I hope this info will help others.
Sorry, dyi would be like $500. SC will prob be $1500 or so I bet. Best of luck and let us know how is goes.I sure hope so! That sounds great. I'm taking it to Milford, CT where I've had great experiences in the past with their service dept. Fingers crossed. I hope to get it towed there tomorrow.
Just to clarify: the posts can appear okay until cleaning and retourqing snaps them.
It seems like they probably should have done the LH ground stud as well, as it seems like they both go around the same time.It was ONLY the RH ground stud that was corroded and I sheared off yesterday.
Do you guys have similar studs on both sides ? On my 13P85 i have an steel bolt on driver side and aluminum stud and nut on passenger side . Both losened easy . Cleaned all terminal ends an put them back , tightened properly .Did not solve my problem . Will order an field rep to come to my place an do some more search . Have seen some videos of badly corroded grounding on the drive unit . Will check those next .I agree, but I did just clean that one up and it bolted back on without a problem.
Was there any corrosion visible? Has the car been exposed to a lot of road salt, big puddles?Got my car back, everything is perfect in the world again.
edit: Even after two weeks, I forgot how much I freaking LOVE driving this car. Next up, getting the N2itive camber arms installed. Woo hoo!
