ElectroCat
HiPlease share your range hit with the alto.
On a 310km one way averaged 310 wh/km, fairly flat route, temp around 25C
Thank you as I see very similar energy use with my Model 3 towing our popup A-Liner. That and the need to unhitch when charging led us to a RAV4 Prime for towing our camper. For a gasser it does well at 31.7mpg or 28 if I figure in gas only on our last 7000 mile trip.Hi
At that high a speed, your range is going to be reduced by well over 50%. I would be surprised if you could tow more than 100 miles on a full charge, and my guess is that it will be more like 80 miles and you will be down to 10% remaining range and need to charge.how many miles can i realistically tow a 2000 lb trailer at 80 mph ? My car reads 261 max from full charge
Or you could go a little slower.that sucks.
I was reading about the F150 lightning full electric, that truck would be pretty useless hwy towing also then. Guess you really need ICE vehicle for towing much...I doubt i could pull 2 dirtbikes to local places esp in winter.
IMO it's dumb to tow that fast on equipment rated for 45 mph.how many miles can i realistically tow a 2000 lb trailer at 80 mph ? My car reads 261 max from full charge. Trailer is 4x8 harbor freight with built sides and holds 2 dirtbikes, so its definitely below roof of the car but not flat either.
that sucks.
yeah on the f150 electric that must be all but useless towing. It’s a brick in the wind and is epa rated at 270 which can prob be divided by 2 real world.
An extra 1000 lbs doesn’t mean much at highway speeds. It increases the tire rolling resistance by about 15% [[1000+6500)/6500] but rolling resistance only accounts for about 20% of the energy needed to move the vehicle at highway speeds. So adding 1000 lbs only decreases highway range by about 3% [15%*20%]. That’s LESS impact than a 2 mph headwind!if they are sand bagging that would change my thinking for sure.
We also have that echo brake controller on a MY with a 2500lb popup trailer. What sensitivity and power.We were using a mount with the max 3/4" rise that Tesla recommends, and it put the trailer perfectly level. I didn't take any close up photos of the hitch, but the ball kit we were using is this one: https://www.canadiantire.ca/en/pdp/reese-tow-kit-2-in-0406899p.html
Tanks were empty for this run, however trailer was loaded with camping gear. Not sure on total weight of the trailer when loaded, but likely just over 3000#.
Using the Curt Echo brake controller. Honestly, it is pretty remarkable how well this car tows without trailer brakes. You can do one pedal driving still with this trailer behind you, however for emergency scenarios we still decided to install the brake controller. Setup was a breeze and took less than 5 minutes.
Car was mostly empty for cargo. Just 2 adults in the front and maybe 50# worth of gear.
Happy to answer any other questions folks may have. First real world trip is next Monday, travelling about 300km and hitting 2 Superchargers along the way.
