I just want torque-vectoring on my LR like the SH-AWD.
Interesting. Thanks for clarifying that. It suggests that they flirted with violating truth in advertising and you had to wonder how any forged wheel could weigh 28 lbs. I'd have to say that the whole Track Pack thing was badly managed. They need to get somebody in there who knows what they're doing. This kind of product just screams Amateur hour.
Honestly seems about right to me. I wouldn’t be that harsh. My e46 m3 with “competition” package came with larger 19 inch rims that were flow formed (front weight 26.1lbs rear 27.3lbs) made by BBS no less. Then upgraded rotors drilled/floating rotors that weren’t amazing on track and would crack at the holes. Then a “m-track” mode which was basically a version of traction control more oriented to beginner track guys if you didn’t want to turn it completely off.
Just a more sporty street car pretty much that may be slightly better on track. Which is what all these upgrades packages from most car manufacturers are anyways. I wouldn’t say it’s really for hardcore track guys at all. Not many OEM solutions are though.
What they really should do is just re label it as a competition package or something. So people don’t get angry at the verbiage. Offer it as a 2-3k upgrade on the performance model on the configurator and use wider PS4S tires instead of sport cup 2.
To be fair, it's not all about the width of the tyre. Without modifying the suspension the factory setup doesn't allow for much negative camber so the stock tyres are going to suffer from premature shoulder wear, whereas the Cup2s with reinforced shoulders, will last much longer on track. They really are very good in this respect on a P3D.For sure those are fair points. I actually think that the sport cup 2 tires are the only truly sporty track-ready part of the package. And interestingly enough the 235/35 OEM tires that are Tesla Spec are believe it or not wider than any 245 / 35 Tire made by Michelin in that Pilot Sport 4S version. If you look at Tire Rack website spec sheet on that tire the Tesla spec 235 / 35 is roughly as wide in terms of tread anyway as an average of several 255 / 35. But they just don't hold up to the heat of tracking.
I ordered the rear "track package pads" from Tesla because my current Endless EX90 track pads have serious brake drag due to the lack of spring tabs that are on the OEM rear pads. They were adding ~30wh/mi to my energy usage and tons of dust.
The Tesla track pads are quite overpriced, $500 for the rears only. I haven't taken them to the track yet but I'd imagine they're a compromise between stock and the Endless pads I was running. But at least I have no more pad drag which is why I got them.
Every time I've used this stuff, it doesn't set the pad properly and I start getting bizarre disc wear. Maybe I was doing something wrong...I use CRC disk brake quiet to “glue” the outboard pads without clip to the caliper. Works very well to reduce drag and noise from lose pads. It’s easy to remove CRC when it’s time for new pads.
I ordered the rear "track package pads" from Tesla…
Or is it because to have the Endless pads on the front and for some reason they don’t drag like the rears ?
I’ve got a $500 credit with Tesla that will expire shortly so trying to figure out what to spend it on. I was thinking maybe the pads from the Track Pack but geeze $500 for one axle seems redic.
How are they in day to day driving ? No squeal ?
Would it be worth getting them for the fronts to run with the stock rears, or would you skip them entirely and stick with aftermarket ?
…if you're just doing occasional spirited mountain drives I'd say upgrading the fronts to the track pads might be a good idea with your credit. Wheels look good!
I attended TeslaCorsa 2 which was enough to realize that 1) stock pads are worse than my fiancé’s stock Civic pads… pathetic really, and 2) I don’t need to be tracking my $80k DD that would need about $8k of upgrades to be able to barely meet the fun factor of my E36 M3 in order to get a single 15min session every 2hrs - lol.
Nope, the P3 will be relegated to canyon cutting Bay Area back roads with my BMW/Porsche/McLaren friends + the occasional autocross domination
To address #1, I’m thoroughly in need of a pad improvement and have no problem resolving the retraction issue myself, even if it means riveting the stock clip onto the aftermarket (just spit balling — I’ve not even seen them yet so won’t know until I do).
So if you don’t mind me asking, in your opinion, have you found a streetable pad that mimics typical stock German sports car street pad compromise ? Basically, low/no squeal, reasonable resistance to high-temp gassing, typically at the expense of dust generation & rotor wear) ?
Would you characterize these pads you have in the front in this category ? And if not, do you have any other candidates on the horizon you’re considering ?
I can’t tell you how much I appreciate your input. Our Tesla community is wrought with what we used to call in the retail sporting goods space, “equipment weenies” who can regurgitate every marketing talking point of every “top” product but still aren’t any better at whatever it is they think they’re trying to accomplish. The ratio of true motorsport enthusiasts vs equipment weenies seems to be especially low in the Tesla circles so we racer types need to recognize each other and work to try and keep the S/N ratio higher =)
Thanks again !
-=dave
Thanks for the kinds words! Sadly I do agree the majority of Tesla owners are not traditional car enthusiasts but often more of the tech crowd. You can see this in a lot of the aftermarket vendors and the junk they sell (eg. rubber caliper covers and lighted logos, etc.) which are embarrassing and cheapen the brand IMO. There are a dozen or so frequent posters and experienced racers on this sub-forum that I've found who have been very helpful for performance modifications. MasterC17, dfwatt, kbecks, MountainPass obviously, etc.So if you don’t mind me asking, in your opinion, have you found a streetable pad that mimics typical stock German sports car street pad compromise ? Basically, low/no squeal, reasonable resistance to high-temp gassing, typically at the expense of dust generation & rotor wear) ?
Thanks again !
-=dave
kbecks: if your advice was that of an equipment weenie, it wouldn’t be worth the electrons it was transmitted on
You come in here basically insulting the community and yet ask for advice then take it from random people on the internet who you don't know after just insulting the credibility of those same people, just a little ironic
Did you take any photos of the Tesla track pack pads you can share? Was there any non-Tesla branding or ID on them?I ordered the rear "track package pads" from Tesla because my current Endless EX90 track pads have serious brake drag due to the lack of spring tabs that are on the OEM rear pads. They were adding ~30wh/mi to my energy usage and tons of dust.
If you haven’t observed the general lack of crossover performance vehicle enthusiasts in the countless Tesla FB groups, TY channels, many forums, etc, then I’m actually envious. It’s generally an endless stream of yet another FB post about some guys new wheel + tire + slammed spring install or yet another Model 3 power trunk or puddle lights YT review video. It feels more like I’m on Hondatech rather than N54Tech
[disclaimer: In another life I used do PGM-Fi reverse engineering for doing custom in-ecu programming, nitrous injection, launch control, full throttle shift, etc, and hosted the first pgmfi wiki that later transferred to pgmfi.org — a forum that sprung out of the necessity to boost the S/N ratio from that of Hondatech in order to attain critical mass of true tech people in order to actually accomplish that very difficult collaborative stuff, but I digress…].
I didn’t see it as insulting the same community I am asking help from. I felt it more expressing a shared frustration rather than directed angst. ‘Didn’t mean it to sound like the latter.
Thanks for the Endless upvote tip. Sounds like it’s a no brainier.
