Not sure what your toll tag looks like and how it works. Here in CA we have 2 flavors. A flat hockey puck white interior version, which some folks have had success with mounted on the inside windshield on the dotted black area by the rear view mirror. There is also an exterior license plate mount version-black long bulky device. I got this one and mounted it with heavy duty velcro and cable ties to the front bumper behind the nose cone. Works great, out of sight.
I used velcro to mount the long black bar tag behind the nose cone. Removal of the nose cone is quite easy. Press your palms at the top of the nose cone with downward pressure.
If you are able to get the external TxTag (black bar) before your car arrives, have them pop off the nose cone at delivery so you can install it.
It's mandatory for me, as the only was to get around in Austin these days is on the tollway. In Austin, they also charge you more if you don't have a tolltag (i.e. read your plates and send you bill in mail), so I will need to find a way to do this. I just can't believe no one uses it--must be an Austin thing.
I have a VIN in the 15,000's and placed the TxTag in the speckled area to the right of the rear view mirror. So far I'm 5/5 in the toll tag being recognized. There was post earlier this year about a batch of windshields that didn't make this area non-metallic which prevented toll tags from being read, but apparently that has been fixed in subsequent cars.
I installed a front license plate (using the J bolts method rather than drilling holes) and got the black plastic tolltag transponder that goes on the front license plate. Looks fine. I should post a picture...
Have been using the ugly black CA FasTrak license plate transponder (NOT the interior version) behind the nose cone (attached to center of black bumper with Velcro & tie wraps) without a problem for months
I'm in Austin and can't get the tag to work for the life of me, but for tolls in Austin as long as you go online and associate your plate with your TXTag you get the discount anyway. The only issue is that when you use toll roads in Houston or Dallas you don't get the discount (and there's one toll road in Houston that doesn't match up plates and tags, I think).Great to know thank u for pic!
