Gizmotoy
Both drivers did listen to the instructions. In the most recent case, the Tesla equivalent of the Check Engine light came on. This happens with relative frequency, just search the boards. It just warns that the car may not restart, which subtly indicates you should get where you're going because once it's off you may be stuck there.Just out of curiosity. I am seeing a pattern here that the fire happens when drivers hit something, the car tells them there is an issue and they continue driving hoping to make it home. Could the 1st and 3rd fire been prevented if the drivers automatically after colliding with the debris listened to the instructions?
That was followed up by the much more rare "Please pull over safely. Car is shutting down." message. Neither driver ignored this message.
Either way, battery fires are runaway chemical reactions. Once the damage is done to the cells, there's not much the driver can do to stop it.
