Once the switch to Octopus (non Go tariff initially) had taken place the meter install was only a couple of weeks later. There was another short delay before they realised they should be transferring me onto GO and using the smart meter readings but all has been well. You've probably chosen a referral to use for your £50 ... but there's one available from me if you need it.
Anyone switched to Octopus that didn't already have a smart meter? If so, roughly how long did the process take and were you able to join the Go tariff with relative ease?
Thanks to all who sent me codes. I got a bit mixed up so used the code that I received first. Apologies to those who missed out.Can you message me too please with a referral code for Octop Go?![]()
It is looking like Agile is going to be a better fit for our useage pattern than Go, which was a pleasant surprise.
Works out to be 20% cheaper for us, so I'd suggest it is worth a look.
Over what period did you compare it? The historical data I saw suggested that the tariff is (typically) more expensive in winter than summer - which makes sense, but is unhelpful if you have solar and so will be drawing maximum from the grid in the expensive months.
Check your messagesDecided to go with octopus, anyone fancy sending me a referral please?
Check your messages
I don’t think I’ve ever managed two minutesCheck your messages
Was good timing. Hadn’t been on today so thought I’d catch up on my mobile and the post had just been addedI don’t think I’ve ever managed two minutes![]()
I switched to it. Once I had the smart meter installed, almost immediately I was on the off-peak tariff. Don’t yet have the car to test it with, but seems to do what it says on the tin.I’m thinking I may go with EDF Go Electric as it’s only very marginally more expensive than our current cowboys Scottish Power but then you have the half price evenings and weekends to factor in so we can switch a lot of our routines to the off peak times. Does anyone have any experience with this Go Electric tariff?
I find that hard to believe!I don’t think I’ve ever managed two minutes![]()
That's a bit too personal Roy...I don’t think I’ve ever managed two minutes![]()
I have EDF Go Electric as I already had a smart meter from EDF and use a lot of electric heating, so the longer off peak and all weekends makes it better suited to my use.I’m thinking I may go with EDF Go Electric as it’s only very marginally more expensive than our current cowboys Scottish Power but then you have the half price evenings and weekends to factor in so we can switch a lot of our routines to the off peak times. Does anyone have any experience with this Go Electric tariff?
