Yes, I meant the socket, the plug is fine. It was only a short term thing while living between houses during a move. The plug in question was old but not that old. Maybe 15 years or so. It's been working fine since but I'm not going to risk it again when I move in a couple of weeks into my new house that already has a dedicated Tesla charger installed.Do you mean socket? The plug on the UMC would surely be perfect. If the socket has been replaced with a standard spec item and properly wired and fitted you should not be risking a house fire by charging at the standard 10amps. I’m concerned that people reading this thread are going to get the impression that home charging is routinely dangerous!
We're on Good Energy so also have a flat rate. Our Toughleads extension with RCD (see past posts) has been fine for 4 1/2 months so far, so your experience over two years is encouraging...!Also been charging using a 3 pin plug for the past 2 years and it's worked flawlessly. The plug I'm using was installed in the last 5 years when I modernised the garage so it will have modern wiring. It's going through a heavy gauge extension cable outdoors to a waterproof plug housing into which I plug the Tesla UMC. I just leave everything outside and it's been fine for 2 winters and still using the same original charger that came with the car. You only get 9 miles/hour of charge (charging at the full 10A) but that's been more than enough for my needs. Since I'm on Ecotricity and a flat rate, I don't need the more powerful chargers to take advantage of cheap tariff bands.
I've been using our external socket. Had a few teething issues - blew the fuse first time, but it wasn't a 13amp fuse for some reason. Put in a 13 amp fuse but then charging would cause the trip to go on our consumer unit. Limited the charge to 7amps in the car and now it works well, if slightly slower.
Yes that's right it was the extension plug. Thanks for the tips, I'll give that a go. Got a bit drive tomorrow and want to charge overnight!The fuse that wasn't 13amps surely wasn't in the UMC? In which case was it on an extension plug? Many are not rated for 13amps.
I'm guessing it would have been an RCD trip rather than an overcurrent trip (if it was overcurrent at 10amps then you've got a problem). I believe that if the RCD is covering the whole board then the tiny earth leakage issues from multiple items in the house can add up and then it can be one extra small thing can be the straw that breaks the camels back. Common culprits are switched mode power supplies that are often found in small USB chargers etc. If you unplug any unnecessary devices you may even find that you can charge at the rated 10amps.
NO! Don't do this. You're basically asking for an electrical fire at this point.I've been using our external socket. Had a few teething issues - blew the fuse first time, but it wasn't a 13amp fuse for some reason. Put in a 13 amp fuse but then charging would cause the trip to go on our consumer unit.
Type A is not sufficient for EV charging. You need a type B to detect 6 mA DC (not just pulsating DC).type A RCBO included, to protect against DC which normal RCDs don’t.
