Update and Good news - The electrician showed up today and fixed the issue. The issue was that ground wasn't connected to anything on the panel side (floating). He said it was left as such because there is no ground bar in the panel but now connected the ground to the Neutral because of the issue.
I sincerely thank all of you for spot on guidance and help. The pictures tell a story. I included before and after of the panel as well as charging status on the dashboard. The black cable at the bottom of the panel is for the outlet. The voltage measurement between hot and ground is now 120v as well.
I also found out that I am getting a JuiceBox Pro 40 for my father's day gift. Will definitely put it to good use. Happy father's day to all the wonderful dads here!
Happy ending.
Thank you!
Nice!
Though these pictures have brought up other questions. Is that the only panel in the house? Is there any other panel outside? A meter at least? Above ground or underground?
How old is the house / that panel?
It looks like nearly nothing in the house is grounded?
I am wanting to make sure neutral and ground are bonded together at the proper spot (they probably are).
But yeah, I really don’t love that panel. It is not one that I know is defective, but it is very very old.
It is a split bus style panel (no main breaker) and it is fed by wire probably only good for 100a (the good news is that you don’t have a ton of load in it).
I have serious issues with an electrician installing a 14-50 and leaving the ground wire flat out cut off. That is bordering on “I need to report that to the licensing board”. Grounding is not optional in 2019. I don’t know what the required procedure is when too come across an ungrounded panel and need to add a circuit. I have never experienced this. (though the panel is likely not ungrounded - that one bus is likely the neutral to ground bonding point).
Can you tell if you have a grounding rod near the panel with a heavy gauge wire from it to the main ground/neutral bus in the panel? You certainly should have one if this is the “main service entrance” (which it likely is). Also, if your water pipes are metal they need bonded to this as well.
I personally would likely be wanting to replace that panel due to age. There is nothing flat out wrong with it, but it is kind of a mess with so few remaining spots on the neutral / ground bus. I also would likely be considering an upgrade to 200a at the same time just because that is more the standard these days and because modern conveniences (A/C) may demand it.
Glad you are charging fast now!
