Unable to reach Tunein after 8.0 update
Discussion in 'Model S' started by bmoroze, Sep 24, 2016.
Tags:
  1. bmoroze
    bmoroze Member
    MA
    Hi all
    I did the 8.0 update, but it seems I can no longer connect to Tunein. I get a message after the arrow spins for a while saying "Unable to reach Tunein. Try again later".
    I can connect to Slacker/Streaming Music, all other network connections are fine. The login to Tunein button is not available either (the login button is available on streaming music). I've tried the screen reboot, etc.
    Anyone else seeing this?
    Thanks
    Ben
  2. slazhole
    slazhole Member
    Northern VA
    I am having similar issues. After the update to 8.0, I tap Tunein and it's just spinning. I don't even get the login button.
  3. lardlad00
    lardlad00 Member
    Milton, WI
    Same issue here. Installed the update last night and drove around for a while today to test it out and tunein never worked. I had it running on my phone just fine, though.
  4. msnow
    msnow Active Member
    SoCal
  5. tinm
    tinm 2013 S85 Owner
    New Mexico, USA
    The problem with ServiceHelpNA (I keep thinking the NA means Not Available) is it seems really aimed at car service as in the physical car. Trying to get help on the software in the car is about as easy as contacting Google for help with a gmail problem.
    All these reports of the media player app being not so hot as Elon made it out to be is giving me a lot of pause in terms of installing 8.0 (if Tesla ever gets around to offering it to a lowly classic 2013 pre-everything Model S).
    I use TuneIn A TON, and if there are glitches in 8.0 for TuneIn, I'm staying away.
  6. msnow
    msnow Active Member
    SoCal
    Nah, these emails get to both the users SvC and Corporate and opens a problem ticket. Like you I use TuneIn a lot and it will help if they fix it before we get 8.0. No what I mean? ;)
  7. evbeliever
    evbeliever Member
    NJ
    Correct, TuneIn login is not working in 8.0 today, but somehow stations from Tunein saved into Fav seems to work.
  8. lardlad00
    lardlad00 Member
    Milton, WI
    How do you access tunein favorites? I don't see mine anywhere.
  9. bmoroze
    bmoroze Member
    MA
    I have sent an email to [email protected]. Hopefully they either know about the issue, will fix it, or provide a solution since the problem seems to be somewhat widespread.
    Thanks all,
    Ben
  10. Beryl
    Beryl Member
    South of Houston
    Yes this is the same with 7.xxx. Once you log out of Tunein, it seems to remember what you've already saved under your user ID but you can't log in again. It is an odd glitch.
  11. msnow
    msnow Active Member
    SoCal
    Someone earlier confirmed they could log in to TuneIn with their personal ID and their favorites moved over in 8.0 so this might be a temporary issue on TuneIn's side.
  12. California85D
    California85D Member
    I am having this problem as well. Can anyone currently use Tunein on 8.0?
  13. tonyquan
    tonyquan Member
    I have a friend with 8.0 where the TuneIn tab works properly, but it doesn't work for me. I've reported the issue to support and they indicated it would be passed to engineering to review.
  14. Apricot
    Apricot The waiting... the waiting...
    SF Bay Area
    I don't use TuneIn much, but yes it hangs for me on launch. Can't even scroll down to enter in TuneIn login info.
  15. bmoroze
    bmoroze Member
    MA
    As of this morning, Tunein is working again. I was also able to log in to a personal account. I had heard back from my email to ServiceHelpNA but mainly to ask me a couple of questions. Perhaps they forwarded the issue and fixed something.
    Also, it seems they may have fixed the "High bandwidth required" issue with many podcasts, as I was able to stream a podcast that never worked unless on Wifi or full LTE strength today.
    Ben
  16. patrick40363
    patrick40363 Member
    Cali
    No problem for me.
  17. jdjeff88
    jdjeff88 Member
    Texas
    I woke up this am to no 8.0 but all of my tunein saved stations were gone. Everything else radio wise was there. My headlights also wouldn't turn off (on auto) in full sun. rebooted but nothing changed. Could find my tunein stations in recently played and they worked, but had to re-add them.
  18. lardlad00
    lardlad00 Member
    Milton, WI
    Tunein is working now for me this morning but my favorites were gone. I had never logged in when on 7.1 and on updating to 8.0 only my terrestrial favorites were saved. Not a big deal as I only had 5 or so but still odd.
  19. tinm
    tinm 2013 S85 Owner
    New Mexico, USA
    I wonder if it makes a difference whether you first go on the web using a computer and log into TuneIn and create a list of favorites that way then log in to TuneIn in the car, vs, simply adding favorites via the Tesla interface.
    Me, I did it the former way.
    All these reports still have me thinking to hold off upgrading to 8.0 should they ever offer it to me :)
  20. msnow
    msnow Active Member
    SoCal
    If it's because of what people are saying about TuneIn problems it seems to be fixed now based on this mornings reports.
    By the way, thank you to those that reported this to Tesla via email yesterday. Seems to have helped.
