I would imagine both would improve ride quality depending on settings. Noise is more tire and soundproofingWith either coilover kits, was road noise lower and ride quality smoother than OEM?
We can also imagine the opposite.I would imagine both would improve ride quality depending on settings. Noise is more tire and soundproofing
Is your guess based on research? It's been discussed quite a bit on here.We can also imagine the opposite.
Felt this picture belonged on this thread
Those are test units from UPP I believe, they said they'd be in summer. They allow camber adjustment.More details on those control arms? Do those solid bushings make a big difference in feel and noise?
Yeah but a well made coilover(while having setbacks) can be better at both worlds than a typical spring/strut. As I said, it's mentioned a lot in this thread. With digressive valving you it will be stiff during slow changes to the suspension(turning, accelerating, etc). Then in faster changes(rumble strips, potholes, bumps, etc) it'll be soft. Obviously this is ideal - so would need testing but Kbecks13 seems happy with it(though he has the sport)Well ride is a whole interactive complex of things including tires especially sidewalls, unsprung weight, bushing compliance, control over oscillations, shock tuning Etc. it takes a lot of work to tune the suspension for the best possible ride. Especially when you got the challenge of an ultra low profile Tire. All things considered the model 3 rides extremely well, and has a pretty close to Ideal ride / handling balance for most people. Maybe not for tracking but given how well it rides it's pretty competent on the track even without coilover kits lowering Etc.
Ok definitely some confusion - but my point is basically that coilovers from either brand (MPP or UP) will give a better rider (softer on bumps/potholes) than stock mainly due to the more digressive valving that they use. They will also be stiffer in corners and give less body roll, it's a bit of "best of both worlds" and again is from the digressive valving.
Not sure why all the digressive valving hype but Sasha at MPP has already confirmed the stock suspension is digressive and as far as coilovers for the model 3, they are only coilovers in the front with MPP and UP as well as the stock units, obviously much higher quality materials in the aftermarket units, as far as ride quality goes i'm happy with mine especially since going to a 255/40/19 conti dws06 tires but of course there is always room for improvement.Yeah but a well made coilover(while having setbacks) can be better at both worlds than a typical spring/strut. As I said, it's mentioned a lot in this thread. With digressive valving you it will be stiff during slow changes to the suspension(turning, accelerating, etc). Then in faster changes(rumble strips, potholes, bumps, etc) it'll be soft. Obviously this is ideal - so would need testing but Kbecks13 seems happy with it(though he has the sport)
One page back
Yeah - there is no way the struts could be as well as they are without digressive but you can change the level of digressive, there is a lot of roll still in stock. I have some good tests for when they arrive.Not sure why all the digressive valving hype but Sasha at MPP has already confirmed the stock suspension is digressive and as far as coilovers for the model 3, they are only coilovers in the front with MPP and UP as well as the stock units, obviously much higher quality materials in the aftermarket units, as far as ride quality goes i'm happy with mine especially since going to a 255/40/19 conti dws06 tires but of course there is always room for improvement.
I would really like to go for a test ride to compare, I would be interested in coilovers if I thought I could both improve comfort while improving the handling.
Yes, our dampers are digressive in both compression and rebound as nearly all modern sports dampers are. As kbecks13 said, the "knee" is simply a high-speed bleed that opens at a certain shaft velocity.
The OEM dampers are also digressive.
Got my kit today. It came with helper springs, so I am confused. Do I just not use it?
You won't be using them! They are already boxed with every kit, so you guys can just keep them as paperweights!Got my kit today. It came with helper springs, so I am confused. Do I just not use it?
if they are already installed with the helper springs and don't creak, no need to retrofit parts?
No creak, all good!You'd have to check with MPP about their recommendations but I always say if it ain't broke don't fix it!
