I disagree Tesla has an responsibility for my behavior on an off-road course because the variables are impossible to control, including the nut behind the wheel
If you're just enjoying a light couple laps the upgraded Tesla brake setup is probably fine. But as others have said, if you really want to push it you need brakes that will really keep their cool and pads to match and tires too unless you want to leave chunks of rubber on the track
I'm not an automotive engineer (but I know some
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
) so trash away but, as others said, most of what's going on in the Tesla track mode is software. When we would race our dumb cars in different conditions, we could change tires, tweak suspension settings, etc but the rest of what happened was the responsibility of the squishy stuff between our ears.
Track mode already has to deal with brand new vs nearly scrubbed tires, brake pads at various depths of wear etc not to mention all kinds of track surface conditions. Tires wear, people inflate them differently, track surface temps are all over the place (potentially) and it could even be wet out there.
Offering increased cooling, adjusted regen should have nothing to do with the above (same old tire slip monitoring). Calming the nannies ditto. Deciding to turn off special-magic-drift mode because of an assumption about the condition/capability of my rear brakes and tires makes zero software sense given some hopefully wide range of compensation for wear, conditions, etc..
Ok continue the 'debate'
