Gary, Thank you for the quick and thorough reply. I'll look a little closer and see if I can find a place for the dongle.
So I made the mistake of pulling the cubby all the way out. It is not going back in easily. Any hints or videos of how to reinstall it?
If you made the mistake of not following the instructions and did more than just unsnap the front of the cubby, you are now going to have to take the yacht floor (or carpet if an older S) out of the bowling alley, and on some cars this is a PITA.
Reach your fingers up behind the rear top of the yacht floor and pull towards the rear of the car and try to work the yacht floor piece out. There is a little black piece of plastic that snaps in on either side at rear of the cubby space that must come out in order to re-install the cubby. This piece pulls out straight towards the rear of the car to remove it. So this also means the yacht floor must come out first. Be extremely careful with the front of the yacht floor where it meets the console. If you have the version with rubber all around then you are much less likely to damage something. If not, and the yacht floor has no rubber surround, then be careful not to damage the corners and/or the rear of the console (where the USB ports are, etc). If you have an older S with only carpet, then it's super easy.
I made a couple of hook tools out of thin tempered strips of sheet metal I found in my junk stash that makes this procedure much easier, but again, just go slow and be careful.
Warning to those that have not fully removed the cubby, DO NOT! Just unsnap the front only and let it swing down. If you remove it, you have a lot of tricky expletive-laden work to do in order to get it back together!
Does anyone have any plans to have the required cabling manufactured professionally, and then offered for sale? I realize a lot of you enjoy stuff like making your own cables from parts, but I'm not sure I'm up to it, and would prefer to pay a few extra dollars for a professionally manufactured cable. It would seem there would be demand, and then more demand for the app as well.
Basically I'm thinking if someone sold a complete system that would just plug in to the OBD port or the TDC (it could be either, right), people would buy it.
I have some extra parts. Do you want me to make you one?
That's the spirit! Thanks for helping out others! I was about to make a bunch and give them away at cost. My problem is that my car is in the shop so I can't test my cable so I won't be able to make more until I can test mine first.
