Chris TX
Chris TX,.
Some might want a much shorter cable, and possibly much more flexible, to be able
to fit the adapter cable and the mid-sized ELM-type Bluetooth dongle up into
the recess above the cubby, and still close the cubby.
How are you intending to use this longer adapter cable?
Would a very small amount of paraffin wax on the cubby's two front contacts
make it easier to pull down, and push back up, the front of the cubby?
I don't have a problem cutting it down if anyone wants it less than 3ft. I've added a note on my listings where people can request it shorter.
As for the cubby's operation, if you want to add a lube to the body clips, a lithium based grease would be best since it won't break down the ABS panels it's touching.
Also, here's the TMC/Panjo listing: https://www.panjo.com/buy/tesla-model-s-obd2-can-adapter-cable-pre-sept-2015-265769
