Qwk: Please name another company that gives more and more features than what they gave you when you got the car.
I don't have any first-hand knowledge as to the specific algorithm. I suspect it's a high-resolution monitor of voltage and time at a sub-second level (which would likely mean firmware-based monitoring by the charger).
@FlasherZ - I'm curious, where do you get the information that the Model S is operating with arc-fault detection? I've not seen this noted anywhere in any documentation.
The voltage drop based charge current reduction is easily reproduced, but from what I understand of the charger and such I'm not quite ready to jump to the conclusion that it is operating with arc fault detection in place.
It seems odd for this capability to have been included as a HW/FW capability yet only have been activated after the garage fire I referenced above (when it almost certainly was).
Are you sure this is the specific event it specifically designed to trigger on for current reduction?
With all due respect, I didn't ask for more features. I just want to keep the ones I paid for. I had 40A charging for over a year, and then Tesla took it away. Yet, Tesla still advertises you can charge at 40A with the UMC on a 50A circuit.
If the Model S onboard charging system detects unexpected fluctuations in the input power to the vehicle, it will automatically reduce the charging current by 25%. For example, this will reduce a 40 amp charge rate to 30 amps.This change is designed to help protect you even when a problem exists that is outside of the car or charging electronics. It should significantly increase robustness and safety in the unlikely situation that a home wiring system receptacle, adapter or cord is unable to meet its rated current capacity.
DavidM said:I have already established that "I don't have a problem with my electrical connections". This is backed up by the experts at the power company. They publish what their standards are (240V, +/-5%). Fluctuations within that range are considered to be acceptable.
Yes:
Log In - The New York Times
The "over-the-air" update they referred to was the charging current reduction in 5.8.4. The fire report makes note of an extremely high temperature point inside the receptacle itself, indicative of a loose connection.
...I think Tesla's doing the right thing by protecting its customers, and it's primarily because my house nearly burned 15 years ago from the conditions (unrelated to Tesla) that the software feature protects against. Assuming you and Tesla have tried isolating the issue by using a loaner/replacement UMC, should you replace your UMC with a wall connector, my money would be on your car still backing off its charge current.
I think that you're an exception and not the norm, because there is only a vocal minority complaining about this on TMC and Tesla Motors forums, with tens of thousands of customers. I don't accept your assertion that most people experience it and just don't know it because they charge at night, because you can see it when you use the mobile app or if you're charging during the day. Those people who are exceptions can do one of three things - 1) accept that you're an exception and enjoy life with a beautiful piece of machinery; 2) fix the exception by finding the problem; or 3) fix the exception by going to an alternative that puts you back in the mainstream. I've told you where you can look, but you're ignoring it because a power company man in the van put his voltmeter on and said your voltage is between 228V and 252V.
My best to you in resolving your situation, should you choose that path. There's nothing else that I can offer that will change your mind, and -- to the others here -- I'll let the evidence stand for itself. I'm proud that my Model S looks after my safety.
I understand the grage fire is what prompted the FW change. I was the one who referred to that initially.
What I'm asking for is are you sure of what the car is triggering on to reduce current? Could it perhaps be voltage fluctuation that the car is too sensitive too or EMI that's confusing it.
In an arc fault situation, maintaining the hazardous/undesired arc in an arc fault situation would generally be voltage dependent across the air gap, no? If it is a series arc fault (a break in one conductor) then a load would be required to make it happen, but I think perhaps my lower level electrical knowledge is failing me on grasping if a 25% reduction in *current* (thus *increasing* voltage) is sufficient to stop an arc fault situation in the first place. I'm not sure that reduction in charge current is an adequate safeguard against an arc fault anyway, which is why I'm confused about the nature of the algorithm. (Disclaimer: speculation, I could be wrong!) Every arc fault protection system I've seen to-date operates by completely interrupting the circuit.
In his defense, I had the same problem. Charged at 40amps just fine before the FW upgrade came along that dialed back the amps. When I charged at 40amps, the UMCs were getting hotter than they should. My first one was so hot I felt it was unsafe and had it swapped. Second one was cooler, but still hotter than I wanted to feel it getting for longevity. Some time later the first FW came out that dialed things back, and I've just let it do it's thing. I've noticed since then that the UMC is noticeably less hot when left to charge at the dialed back current 30amps. For me the difference in time didn't matter much because I can recoup all the miles I drive in my commute to work at 30 just fine... but it is also a little annoying to me that the UMC feels hotter than it should (especially in the summer) when charging at the full 40. This is a UMC that is in a garage, in the shade too.Qwk, you got problems. One of which is your attitude. If all you want to do is complain, well go ahead, but don't expect much help, either from Tesla or from people here. If you actually want to work to find the issues and problems, then stop complaining and start listening to what people on these forums and what Tesla is saying to you.
You've gone through SIX UMCs??? Houston, we have a problem. If your NEMA 14-50 adapters keep melting, then I would say the problem is with your receptacle. If the software keeps dropping charge current that also points to the receptacle.
It was hard to tell in your posts, but do you regularly charge at RV parks? Have you done so recently and had a current drop?
Tesla is saying that they mean to keep people at the latest software revs. You are saying that you don't want that. You either need to accept Tesla's policy, or sell your car.
If the MS originally had a non-peak reading voltmeter on the screen, could TM have changed it to a peak-reading vm simply thru a software upgrade? Wouldn't that be necessary to support FlasherZ's idea that it now can sense arc faults as opposed to just voltage variations within +/- 10% or so?
If I were qwk my next step would be to pull out my old crt scope and see what noise might be riding on top of the 240vac. But apparently his problem has abated for the time being. But DavidM continues with an identical issue - (big shameless hint!)
That's the crux of one of my questions: it seems the arc fault detection would need specific hardware support, thus it would have had to have been there all along in order for a firmware upgrade to take advantage of it.
Which other of your appliances draw 40 amps for 8 hours and require a tollerance of +-5% ?
Since we're all pretty much topping off every night, or every other night, we're almost never "drawing 40A for 8 hours". One and a half hours at 40A would be more accurate.
