spaceballs
Actually if the car charging hardware isn't working 100% the datalogs reading could be wrong, so AmpedRealtor still has a valid point.... You do realize that this car datalogs, right?
Forgive me if this was already asked, but did OP have an electrician check his wiring and power supply for anomalies? That would seem to be the logical thing to do.
I'm not sure what data logging has to do with your electrical wiring. All the car's logs can do is tell the engineers what type of fault or error occurred. It won't tell them what specific part of your electrical and power supply system may have triggered that error or fault. The car isn't psychic and doesn't know what's behind your walls. That's between you and your electrician. Obviously the car is encountering something in your electrical system that is causing a fault. You've gone through multiple UMCs, all of which exhibit the same behavior. The logical next step would be to have an electrician check your wiring for anomalies.
I've only skimmed the thread, but I must admit I'm somewhat intrigued by the idea of finding a couple Model S owners to join me on a road-trip to qwk's place to try his outlet.
On the flip side...
@qwk - If you find yourself in the Seattle area, you're welcome to try my 14-50 outlet with your car. Also we could try various combinations of outlet/umc/car to try diagnosing over some tea.
"I paid for 10kW charging, and received it. Now they are taking it back. Not cool." and "Tesla's choice to limit charging current after the fact is the entire problem." are the comments I'm referring to.
Tesla isn't 'taking it back' it appears they have tightened to tolerances allowed most likely for safety reasons.
I would think after 6 UMCs bad luck with getting a bad UMC might account for the first 4-5 of them but at some point there has to be something else going on to cause so many to break down. There have been issues with UMCs and some getting 2 or 3 different ones until they get one that works but 6 bad ones is a stroke of horrible luck if the wiring and everything else is working perfectly.
If an HPWC isn't an option maybe a robust ClipperCreek J1172 station and using the adapter might be an option at work.
I've charged at 40A for over 2 years and have never had this issue with any firmware version and in multiple locations. Not everyone has had the same experience charging at 40A with this software release. Obviously some have an issue (real or perceived by Tesla's software) that is causing it to limit the Amps delivered to the car.
It's great that you don't have the issue, but it's clear to me that thousands of customers have this issue - including me. I used my Model S and UMC for 14 months and charged at 40A without any issue. Then after FW 5.8.4 the car refused to charge at 40A. It backs off to 30A. I've had multiple visits from the power company and electricians and Tesla Service center personnel and everyone says the 50A circuit is fine and line voltage is within acceptable levels. The tolerances in Tesla's firmware update are too aggressive. As a result, thousands of customers are no longer receiving the charging capability that they paid for (40A at home).
Basically if you don't have squeaky clean voltage coming to your panel with minimal fluctuations, you will likely have issues trying to charge at 40A. It's counterproductive when owners who don't have the problem scold those who do, as if it's their fault. Since the car requires electricity to be used as intended, I consider it an expensive appliance. Every appliance must be designed to work within the same tolerances that the power company deems to be acceptable. Tesla now requires tighter tolerances for Model S. This is bad for business, and it's getting out of hand.
Unlike a dishwasher, all Tesla needs is one horrible garage or house fire to pretty much screw over their entire plan for widespread EV adoption. They're obviously erring on the side of caution.
People need to get their wiring checked out and fixed because by definition that shouldn't be happening.
Rheazombi, DavidM said he has had numerous visits by his electric company and his electricians (plural), and that they indicated there is no problem with his line voltage and wiring. So, at least for DavidM, it does not appear there is anything with respect to his house wiring that needs to be fixed, as you suggest, but rather something with the car (software or hardware) that needs fixing.
You could even have a 48 kW stove, and it would still come nowhere NEAR the load and stress the Tesla puts on your electrical system.
My voltage drop when the car starts charging is only about 4%. I've checked this both day and night... and the voltage drop varies very little. At my normal 3am charge start time I don't have significant other load in my house except for air conditioning running during the summer. Even when that kicks in it doesn't change the voltage drop much.
The other trigger point that has been discussed is line noise. There are very few loads in my house that possibly trigger during my overnight charging timeframe: HVAC, dishwasher (occasional), coffeepot, or refrigerators. Three of those have motor startup loads which can cause some line noise. The rest of my house loads are pretty static.
The car will happily charge for weeks at a time with those loads going on or off all the time without issue. Then occasionally, like this morning, it will be reduced. This is particularly annoying as I time the charge to end as I'm goging to leave in the morning, so I have a nice warm pack on these winter mornings. Starting some days with 25% less charge than intended on single-digit temp days can be a bit of a pain.
What's odd is that I have LOTS of other noise inducing items in the house: a rack of servers, a dozen other computers/DVR's/STB's, a couple dozen lighting controllers/dimmers, etc... lots of things with switching power supplies or PWM circuits that generate EMF. None of those seem to bother it the slightest.
Given that the max power you can charge your Model S at is 20kW, what do you mean by this?
Correct me if I am wrong, but Arc Faults are usually at the termination of a circuit, or at a breaker, so that would not be the the power companies responsibility anyway, or am I missing something?
A stove or electric heat unit rated at 200A would still never come close to the continuous charging load that the Tesla puts on your infrastructure.
It is *the* largest load that most homes will ever see.
