First and foremost -- THANK YOU!! It is working fine for an 85D delivered a couple of weeks ago.
Second, it may be just my impression, but it appears to me that my iPhone app has been connecting more quickly with VT running.
Does anyone know if VisibleTesla can be properly run on a high DPI display on Windows 8.1 with the scaling level slider all the way to the right?
One more interesting tidbit. When I charge using a CHAdeMO adapter it's showing the charger power as a negative value
Update to Java this morning has broken VT, redownload and reinstall did not work. Any ideas?
Please use the Make_Windows_Shortcut script when you install VisibleTesla for the first time on Windows. This is not new and is technically not required. However, using this approach insulates you from changes to Java that Windows might make on its own.
