I suppose it’s sufficient for wondering but I think it’s too early to suggest any kind of longer-term trend or pattern.
The general pattern is pretty simple:
* all charging spaces support any CCS-capable car and are capable of “150 kW” CCS or better
* Typically 2 of the spaces support up to “350 kW” CCS
* One space supports “50 kW” CHAdeMO or “150 kW” CCS
This pattern has been seen at locations with the minimum 4 charging spaces and at locations with the maximum 10 charging spaces being installed over the next year. Every site so far has a CHAdeMO space and 150 kW CCS spaces but it isn’t certain whether all sites also include 350 kW CCS charging spaces although most seem to.
The “50 kW” CHAdeMO cable and plug is actually capable of “100 kW” (200A) CHAdeMO and will be upgraded via a software change and further testing and certification. I believe this may be happening at some European non-EA ultra-fast charging sites as well. Although the CHAdeMO specs have officially supported 400A since the spring of 2017 there still are no certified cables and plugs from any supplier supporting that power level. When 350-400A liquid cooled CHAdeMO cables and plugs are available it should be easy for Electrify America to upgrade these CHAdeMO charging spaces if they choose to do so since the charging pedestal already supports liquid cooled cables.
