I've owned my Model 3 for 5-6 months now and since then the wall charger has been working flawlessly, now suddenly it's causing the breaker to trip. Admittedly the breaker we have is definitely make shift and older, but it still works regardless and has the capacity to power my car. At first me and my dad thought this was probably due to the pool pump being turned on and working overnight alongside my car charging, which would make sense, so we restarted the breaker, tried charging again without the pool pump running just to make sure and after about 1 hour of charging, the breaker tripped again!
To add some context, the wall charger unit has been running at 48 amps for the past 5 months, after it tripped and we thought it was due to us needing to run the pool pump, I put the amp limit to 25 amps just to be safe, obviously didn't change anything. Any ideas as to why this could be happening?
