For purposes of this thread L2 is NEMA14-30 (or better), NEMA 10-30 (or better) and/or 208-240v charging.
I'm trying to join forces with an EVSE manufacturer to provide charging guidance for drivers who want to depend on the vagaries of the variable wind generation in the U.S. Great Plains. If everyone has chargers before they get their car, it might be challenging to get sign-ups for this specialty EVSE/charger.Ok pole, but why ask this question?
I don't know why this got down voted presumably people believe HPWC is the only way to go even though you mentioned that as another option.. then again maybe it's because you misspelled losses14-50 is what you want or the wall charger.
The car uses a percentage of the power to heat the battery, run pumps and power the controller. These are all looses and the higher the power of your charger the lower the percentage of looses you get.
A standard wall outlet 10amps at 120 might have 20-30% looses just to power the car, costing you a lot more money to charge than 32ax240 or 40ax240 setups.
Heat is also the enemy. I installed a current sensing relay that turns on a fan to cool the charger when it is active.
While technically correct and a 10A 120 really isn't a good option, 14-50 is overkill for the majority of people. A 220 - 30 or 40A circuit is plenty of power and avoids wasting money on heavier copper wire. Depending on the situation, a 240-20A may be fine.14-50 is what you want or the wall charger.
Meh.. the wire size is a small fraction of the cost of an install plus it's worth planning for a 2nd EV in the future.. not to mention you'll get the money back on the wire size with the efficiency gains.. 50' of 6/3 is only $50 more than 8/3While technically correct and a 10A 120 really isn't a good option, 14-50 is overkill for the majority of people. A 220 - 30 or 40A circuit is plenty of power and avoids wasting money on heavier copper wire. Depending on the situation, a 240-20A may be fine.
I did the install myself, so the difference was not an insignificant amount of the total cost and the efficiency gains of 50 vs 30A are insignificant. Don't forget, many people don't have 400A service. If you have 150A service to your house adding a 50A circuit may require upgrading, adding several thousand dollars to the cost.Meh.. the wire size is a small fraction of the cost of an install plus it's worth planning for a 2nd EV in the future.. not to mention you'll get the money back on the wire size with the efficiency gains.. 50' of 6/3 is only $50 more than 8/3
You're gonna downvote someone that suggests the most efficient install just because you only have 150A service at your house? You are one cutthroat internet badassI did the install myself, so the difference was not an insignificant amount of the total cost and the efficiency gains of 50 vs 30A are insignificant. Don't forget, many people don't have 400A service. If you have 150A service to your house adding a 50A circuit may require upgrading, adding several thousand dollars to the cost.
Well, the ‘downvote’ was intended as a disagreement to saying you 50A was all people should consider (which I explained in my response).You're gonna downvote someone that suggests the most efficient install just because you only have 150A service at your house? You are one cutthroat internet badass
He didn't say it's all you should consider he just said you want 14-50 or an HPWC (which incidentally could be 30a)..Well, the ‘downvote’ was intended as a disagreement to saying you 50A was all people should consider (which I explained in my response).
The downvote to your last post was just to be a jerk!
