Oh, I understand the range is reduced. I got this. It is when MY is charging, it stops with 505km on the display. Is this how it is supposed to be?
I tried charging to 100% for the first time and got 505km (~314miles). I got me MY in late Oct, never tried the "Trip" option until recently.
I was expecting to see ~525km (~326miles). Not a huge difference but is this how it is supposed to be?
I don't know about you all, but my full charge range is going up and is almost at 350!
Seriously though, stop obsessing over full charge range fluctuations... you're wasting your time worrying about nothing.
Based on what I’ve read, and what I know about lithium battery chemistries, the reason for the fluctuations in full charge range estimates has to do with the BMS’s requirements in order to maintain an accurate calibration of the pack’s true capacity.
To summarize, the BMS needs the MY to sleep for several hours at various states of charge so the BMS has multiple samples points to then build an accurate estimate of the pack’s true capacity. What tends to happen is the user charges the pack to the same state of charge everyday, without allowing enough time at other SoC for a proper calibration.
From my understanding, this is all due to the lithium battery chemistry and it’s flat discharge curve. To put it into perspective, the difference in cell voltage between full and empty is around 1 volt with lithium chemistries, compared to around 4 volts with lead acid. This characteristic makes it difficult to estimate the MY’s full charge capacity, especially when ideal calibration conditions aren’t provided to the BMS.
How do I know the reduced range is due to the BMS and not due to degradation? As far as I can tell there’s virtually no way to prove what the actual range is because when you go on a long trip you can’t keep your avg. Wh/mi exactly where it’s rated, so how would you know exactly how many miles you should be getting without the computer telling you?I don't know about you all, but my full charge range is going up and is almost at 350!
