What I can't quite figure out from the above graphs, and the original document from Panasonic (
http://industrial.panasonic.com/www-data/pdf2/ACA4000/ACA4000CE240.pdf), is if this is the equivalent to constantly range charging the Model S, then driving it so that the discharge rate is constant at 1C, emptying the battery to 0%, waiting 20 minutess, then range charging again etc. It says in the graph that the cells start off at 4.2 V (range charge equivalent?) and discharges at 1.0lt (equivalent of 1C?) and down to 2.5 V (equivalent of empty/0% on the Model S?) and doing this in a temperature managed state (at 25 deg. C or maybe at maximum 25 deg. C?).
