I have an AWD and with previous 8% and now pending 5% bump I calculate my car at 392 hp. Am I doing that right? I'm also thinking AWD will now be 3.9 sec car (w/rollout) which puts it even with BMW M3 and Alfa Quad. Performace models both. Then I'm thinking the original hp number for P3D was 450. So 510 hp after the past 8% plus this coming 5%? Or did P3D not get the 8% the AWD was reported to get?
I don't think the previous bump on the Dual Motor Performance version was anywhere near 8%. Probably barely four or 5%. But one of the things you have to keep in mind is that the horsepower numbers for electric vehicles have a certain level of 'promotion factor' relative to drivetrains on an ICE car. Two reasons for that. There is no awkward 90 degree torque translation associated with a drive shaft. That drive shaft really creates significant parasitic losses and some people estimate that for example in a four-wheel drive vehicle drivetrain losses can be anywhere between 12 and 18% and as much as 8 to 12% for rear wheel drive. We don't have precise numbers for the Tesla system but I suspect it's somewhere around 3 or 4% tops.
So in that sense our horsepower numbers have to get bumped up to be compared to an internal combustion engine vehicle with a conventional transmission. Additionally there's less parasitic loss in direct drive compared to most transmission although the difference is probably only a few percent. Last but not least, electric motors have a very flat horsepower curve unlike peaky gasoline engines.
The one disadvantage is that our horsepower output drops as you get up into the higher speed ranges, depending on gearing of course but in the Model 3 it starts to drop off at about 45 miles an hour. It doesn't drop as much as a gas engine would running at twice its peak power RPM (which would be way past its Redline and probably blow the motor up!). And then there's how Peak torque is available way lower in the motor RPM range than even on a turbo car.
When you put all that together it explains why for example the model 3 can get to 0 to 60 in just a tick over 3 seconds when its power to weight ratio is not as good as a BMW M3 which it pretty much Romper Stomps but which can have a similar trap speed. It's also though why our ET in the quarter mile which is around 11.5 or 11.6 in the performance version is so much better then our trap speed. One possible solution of course is to have two gears but that adds weight, complexity and parasitic losses.
