you need dual chargers if you will need to drive 250miles, then require a charge to be "as fast as possible" so that you can get on the road again. Without dual chargers, you will regain approx 27-30 miles of range per hour of charging at 240v/40amps (with dual chargers it will be twice as fast). If you are doing a road trip, you want a Tesla Supercharger or a CHademo as a second choice. It would be a rare situation to be able to use your dual chargers while on a road trip due to the limited supply of high amperage chargers - but maybe you are in a situation where you have a friend who is a fellow Tesla owner and has a installed 80 amp service. No point in getting the dual chargers, in my opinion, if you are not able to install 80 amp service at home (make sure you can put in 100amps more into your main panel and are ok with spending a bit extra for the installation). There are some that say slower charging is better for battery health, so I personally wouldn't crank up the charging at home just b/c I could...
listen to the Tesla rep -- truly a company that puts their customers first.
