JeffK
Can you cite a source for your high amp charger sales numbers?Designing a new design for 1-5%? I don't think so.
Assuming the car recharges fully overnight when plugged into 240V 50A outlets, as the Model S and X do (at least until the longer range 100D) it's not going to have any measurable impact on superchargers.
You are probably right.Assuming the car recharges fully overnight when plugged into 240V 50A outlets, as the Model S and X do (at least until the longer range 100D) it's not going to have any measurable impact on superchargers.
Can you be specific: how many amps M3 "high amp charger" makes?Can you cite a source for your high amp charger sales numbers?
1) I know that M3 will be sold worldwide
2) I know what 20-40k EV owners have at their home/apartment (mynissanleaf forum). Many struggle maxing out optional 7kW Leaf charger, some are extremely happy with 120V brick
3) I know that most people are happy with 3kW on a vehicle that uses less energy than Model S per distance. Including me.
4) Lots of people have 3-phase 400V connection. The only way to (easily) get above 16A is to use multiple phases. Including me.
5) I know the average distance traveled and how much energy must be taken on board during the period owner sleeps.
6) Sleep is unavoidable.
7) Tesla dropped 20/22kW dual charger. "Shut up and take my money" doesn't work as we see. It appears 16kW is good enough upgrade for everybody. Even Model X users. Therefore much less needed on smaller EV-s.
US actually has an advantage in terms of available power. 200A 400A main boxes is absolutely unheard of in EU for private houses. US is one of the most power hungry in terms of "energy per household" - therefore lots of amps are available on average.
I'm pretty sure this also applies here:
I'll give a realistic example for a huge chunk of the world: 1 phase apartment with 40A at 230V. 3-phase private home with 3x32A limit though not 96A on neutral, main breaker 63A sum. If Model 3 will be capable handling 400V (between two phases, not phase-vs-neutral) half of the world could actually get more juice, otherwise lots of trippings. Or... Tesla's stationary wall mounted EVSE will monitor main circuit breaker load and act accordingly. Without additional hardware some already use. Reason: 3-phase charging consumes equal amount per phase right now. Phases can be loaded differently. Overload can be tripped on any phase separately. Very hard to monitor that manually. 1-phase connection is easy: you have what you have. Just sum all appliances.
Solution to all of this: being realistic with home charging needs. 70kWh during the night two nights in a row? Less than 5%.
A leaf is lighter than a model S
lots of people can hire an electrician to wire up what they need
No. If there is no DC I will not be a waypoint. Luckily it is hard to find a spot without DC (at least 50kW) nowadays. And it will only get better. It's weird that in US Level2 is considered as a place to charge the vehicle during the trip (except destination). It is not where the wind of change is blowing. It might have been years ago when EV's had like 15-25kWh battery pack.I see you've never traveled. You'd have to charge while you're awake and waiting for it. If you're outside the range of a DC station then you need a fast onboard charger.
Are you going to sleep in the middle of a road trip when you've only driven 215-300 miles?
Destination is the point you arrive to. It can be home, it can be hotel. You don't go there to wait for a charge.There's no reason home and destination "chargers" can't deliver decent power rates to the internal charger.
Yes it is single unit. As far as I know, Tesla does not offer anybody dual 16,5kW charger. Guess why. There are plenty of "shut up and take my money" customers.The dual chargers was just that dual chargers. As far as I know the newer 16.5 kW charger is a single unit.
I know right? Yet you saidLook at the topic of this thread. We are talking about Model 3.
I'm going to wait no more than 40 minutes in any situation. Whatever the onboard charger, that is way too little, be it 3, 6, 10, 16 or 20kW. Like I said, decent is from 0% to 100% within the night.
6) Are you going to sleep in the middle of a road trip when you've only driven 215-300 miles?
Many hotels have time limits for parking at a destination charger so you'd be waiting anyway or risk getting towed and second, if it happens to be a waypoint, then even 40 min at 16.5 kW will yield a greater charge than 40 min at a lower power thus proving it's better to charge faster because you're imposing a time limit.
