LukeUK
Climate control had been on for 30 mins or so, it was toasty warm, once we actually got inside!
I'll be turning it on earlier if it's as cold tomorrow morning.
And if prevention or giving it a judicious thump doesn't work use an old style hot water bottle held against the handle area for a minute. It only tends to happen with a relatively unusual combination of rain quickly followed by a freeze.
That may be so, but the 2017 Evoque I drive (until 10th December) has such a device. I don’t like the reflections from the filaments either.Ford I believe have the patent for heated windscreens. Personally, I don't like the tiny filaments in the glass.
I think Ford have a patent on it
Tesla have a partially heated windscreen on the MS and MX although it only covers the area where the wipers rest. . Not sure why its too high a current draw when you can put the rear glass heater on.
warm water. chuck that over the door handle
The high current just can't be an issue ... I would be in readiness to eat my hat if that turned out to be real!
Resting a bare buttock on the handle might work but could amuse/startle those nearby
Rear screen typically 12A up to 15A depending on temperature. Front screen 20A up to 23A depending on temperature and don't forget you will often run both at the same time.
Tesla have already had problems with the 12V battery getting killed by their standard electronics, so while these are trivial numbers for the main battery it's a load that the 12V could do without right now. If enough customers ask for it I'm sure it's something they could provide, I just doubt it was a priority - much like the heated steering wheel on the M3/Y.
Visions of it being so cold that someone's bare backside got stuck on the frozen door . . .
urine may be the only conveniently available warm liquid.
The Model 3 12 V DC-DC converter can reputedly deliver up to 200 A, and as the main contactor will be closed, so that DC-DC converter will be running, whenever the car is awake, it shouldn't be a problem to deliver ~250 W or so to an electric front screen, at the same time as running the rear screen heater.
Most aircraft (at least larger types) have heated screens, have had for years. They use laminated glass, with very fine wires embedded in the plastic laminate between the two sheets of glass. The main problem for cars, and the one Ford overcame with their patent for their thin metal oxide coating system, is that using such very fine wire means the resistance of the element is high. Not a problem on aircraft, as heated screens are pretty much always powered off the 115V 400Hz supply, rather than the 28 V DC supply.
I'm pretty sure other cars have since used the Ford system, as the Land Rover my brother owned a few years ago had what seemed to be a thin film heated screen, with no visible wires, which suggests it was using a similar metal oxide film system to Ford.
I'm not sure where the GPS antenna is, but if that's located somewhere where it needs a sky view through the windscreen that might be an issue, as this sort of screen heating blocks RF a fair bit.
New According to a thread on this very forum it's in the same pod as the front camera: 2019 Model 3 GPS Antenna
