…It's quite irresponsible to be driving in weather requiring snow tires with summer / all-season tires, regardless of whether one has AWD, FWD or RWD…
A responsible driver knows the limitations of his/her skills, his/her car and his/her tires.
Does not help if somebody else cause an accident or if an animal suddenly step out on the road. Accidents also happens to the most responsible driver….
Now we’re tilting at windmills. If I, as a responsible driver, drive on my All-Seasons let’s say 40% slower than you do on your snow tires, then my risk is the same. I’ve compensated for the longer stopping distance and poorer cornering by driving responsibly (ie slower).
You just determined that probably somewhere around 95-100% of drivers aren't responsible drivers....
How in the world did I just determine that? This certainly isn’t my experience in Colorado. The great majority of drivers here are cautious, if not overly cautious in winter conditions; it’s the 1% egomaniacs who cause the rest of us grief.
Colorado has what is colloquially known as the “Chain Law”. It normally is only invoked on the high mountain passes during extreme weather. There are two levels of restriction. The first level is only very rarely implemented. Note that the Colorado Department of Transportation specifies that AWD vehicles meet either level even with only conventional treads.
1. Chains Only
When this level is in effect, use of conventional, steel-link chains is required. Four-wheel drive vehicles are permitted to operate without tire chains.
2. Chains or adequate snow tires required
This level requires the use of snow tires or traction devices such as cable chains, etc. Snow tires must have the mud and snow (M/S) or all weather rating from the manufacturer on the side wall.
When chains are not used to satisfy the requirement, the following standards apply:
Conventional mud and snow tread with (M/S) with or without studs and a minimum tread depth of 1/8". Studded tires can be used year round in Colorado.
Tires of the all weather type bearing the mark M/S with a minimum tread depth of 1/8".
Wavy snow-treads with steel wire protruding. (Whatever that is)
Four-wheel drive vehicles (all four wheels engaged) with adequate tires: Adequate tires for four-wheel drive vehicles include those with conventional tread with a minimum tread depth of 1/8" and those listed above.
Skiers and mountain dwellers are more likely to put on a set of snows for the winter. Flat-landers typically use all-seasons unless they have a second set of rims, in which case they may run summer and winter/all weather tires, depending on the season. Snows are not used that much since we rarely see big snow on the plains. Since everyone else is driving on all-seasons, you aren't going to be going anywhere quickly when that happens anyway. Our great insolation results in clear roads within a day or two following most snows. Unfortunately my unpaved driveway isn't as forgiving. All seasons coupled with AWD are fine, but RWD even with my Sottozero M/S winter tires doesn't cut the mustard when the approach to my garage turns into a sheet of ice. I don't think snows would help that much, unless they were studded, but then you have fairly noisy tires when running on our typically dry roads.
