On my way up I am thinking I might be able to use the 14-50 you mentioned at the Dells as an emergency backup. Where is that BTW? Yes cold is the biggest challenge for my Model S. I have been getting pretty good mileage this fall. But today for instance on my way to work (about 32 miles) I got around 450wh/mi which is a lot worse than the 350 wh/mi is getting not too long ago. I was blasting the heat and didn't pre-warm the car much before I left. I am still running FW4.5 so it will be interesting to see if I can yield any more range out of it vs. FW5.8. Also, I generally run in range mode all the time. I am not sure but that might do less pack heating then running in normal mode. Do you run in range mode all the time?
It would nice if they had a "cold pack" mode for such situations when you are running at less than 50 miles. It seems it can take 5 to 10 rated miles out of the pack just to heat it up. When you are operating at less than 50 miles, every mile counts. Having regen disabled and maybe limited top end power would be OK in that situation I think. Not sure what the other implications would be.
Speculation: It may be that a cold pack is going to give you less miles than a warm pack. A cold pack that gets "warmed" may give you more miles when the pack is closer to full. At some point it will be that you will get less miles trying to heat a low pack then if you were just to run the pack cold. So the software may already be making that calculation. I have seen a message when the pack is low that "pack heating is reduced" or something like that. It maybe making that calculation that there is no point to heating the pack to get more range because heating the pack would consume too much range :/
So, hoping you made it to Mauston. What was the highest kW you charged at? I didn't get over like, 63kW charging speed, even with a hot pack.
