Which BEV on the market during the first 12 months of Bolt EV sales is likely to have better performance and/or EPA range at a lower cost? Model 3 if they keep to their schedule and GM doesn't slip theirs. Anyone else?
If the only performance metric is AER, none. However, that's not what I was discussing. The Volt, for the Avg. driver, handles all of their daily commute at 100% AER, and then can be taken on a road trip, anywhere. That is a performance metric. There are other PHEVs coming on the market that will have similar performance.
Then there is the Leaf. For a daily commute it can handle the majority of Americans travel on a single charge. It's not as practical as the Bolt to take on longer trips, but then the Bolt isn't particularly practical either. However, the Leaf is currently being sold for at least 10k less than the Bolt is set to launch at. Pretty significant factor, if you don't actually need more than the Leaf's range...as the majority of Americans don't.
Even if we consider the Bolt having 200 miles, allowing greater long distance than current competitors, you have the fact that GM went with a tall vehicle, which has more cargo room (which you rightly point out as a positive), unfortunately this becomes a disadvantage at Hwy speed. The Bolt will undoubtedly get considerably less range at a sustained 65-70mph...and as we've discussed the CCS network isn't particularly fleshed out...and certainly CCS 2.0 is non-existent.
So, for the Bolt to be appealing you basically have to ignore that it costs more, but will return similar functionality as competing vehicles (For the Avg. US driver), or you have to prioritize vertical cargo space above anything else.
I understand that the Bolt works for you, you make a good case for your own use. However, your use is atypical of American drivers, or at least, it's not how the majority of people use their vehicles.
