I'm fairly sure that is not the case. I seem to remember a mention of a breather vent, which is normal for a gear case.
Only Marketing people believe in "Lifetime Fluids". Breather = contamination.
It's most definitely wet. They use Dexron VI in there, it's filled almost half way up in the case with it.
I've drained and refilled several cars, and so far I've found very little metal on the magnetic plug.
Tesla does a drain/refill every year, so I'd recommend you do it yourself if you aren't taking it in.
That would be my guess, fill at the black plug till it reaches that level.
I am just over 95 K miles and 4.5 years with no drivetrain replacements.
I am nowhere near the lowest (I may have the most miles at the lowest thoughCorrelated to holding the world record for the lowest lifetime average Wh/mi?
I've been to Nebraska...ya guys don't have many corners to turn!!I am nowhere near the lowest (I may have the most miles at the lowest though
When I was about eight or nine, a father of one of my friends told us, "Every time you accelerate a bit too hard or go around a corner a bit too fast it costs you money". I've found that to be true. (Note: I am originally from Nebraska. For those who aren't or who don't know anyone from there, the average stereotypical Nebraskan makes the average stereotypical Scotsman look like a spendthrift.)
I've seen the service manual. It most definitely says drain and refill the gearbox fluid during the annual service. The fluid they specify for the rear (small and large) is Dexron VI full synthetic, and the front is Mobil SHC 629. Not sure why they are different, but they are. The large rear DU uses 1.5 quarts, the rear small is 2.4 quarts and the front is 1.8 quarts.
Here's the procedure: (for the large rear DU)
OK guys...this started out as a warning that (some) early cars were having drive unit failures. Should I be worried that my 2016 dual is vulnerable to that early design flaw - or have the engineered a fix to this flaw?
