Nurburgring Alloy Wheels by TSW
page says 23.3 lbs for the 20 X 9" wheel... I remember the rims being about ten pounds lighter than the stock Tesla 19s I removed. The nice thing was that all the weight seemed to come from the rim area which dramatically reduced rotational intertia.
The tires are Pilot Super Sport 255/40 ZR 20. I believe I used the Porsche variant that has a less rounded or more square patch to sidewall which provides a bit wider contact patch.
The only issue I have with aftermarket rims is I've found I need to buy a spare when I buy the set of four. I've been caught out a few times where I've damaged a rim years down the road (pun intended) only to learn that the series was discontinued. I've taken to buying a spare and have not needed it since. Go figure.
Question. This is my FIRST post, btw. I talked to T Sportline and they recommended only for Model S the tire size 245/40-20 for 20×9.0″ wheels with the TST 20s. They also stated it will be dangerous to install a 255/40 ZR20 tire on the TST wheels. Does anyone know why they are saying this?
Should I follow their recommendation?
SPX,
Make sure you have a die grinder or a torx set and a belt sander handy. The pockets on the hub mounting face of the new wheels does not line up 100% with the protruding brake disc retention screw. I marked the part that hit the wheel with a sharpe then removed the screw and used a belt sander to remove just a bit of the head so that the portion that was hitting was not flush with the disc. You'll see what I'm talking about when you pull one of your stock wheels (if you do not already know).
You may want to snag a spare rim just in case you take one out years from now and TSW is no longer making them. It happened to me once in the past where I basically scrapped the other three rims. I learned my lesson, buy a spare as cheap insurance and have not needed one since.
Thank you for the infoThat said, I only got the 255s because the 245s were out of stock. It looks like the 245/40-20 is once again available, so you may as well get 245s.
"switch to 20 inch rims, you might risk damaging the Tesla’s body structure. And in doing so, because the damage is caused by a 3[SUP]rd[/SUP]party product, will as a result void the warranty." Hmm, that's concerning...
