Currently driving and early 16 P90D from FL to Minneapolis and I'm concerned with my supercharger speeds.
Last night, I arrived in Ocala, FL and about 15% and plugged in. Charging started at about 78kw and quickly tapered before even hitting 50% didn't see much past about 40KW through most of my charge, most of which ended up in the mid 30's. I called roadside, and they suggested shutting the car down manually through the center display. I did that when I reached my hotel in Valdosta, GA.
Set the Valdosta charger as my destination, 4mi. Saw initial speeds of ~112kw and it hung in just under 60kw until about 75% when I unplugged.
My next two charging stops were bad...about 33kw at the next stop.
Currently sitting in McDonaugh, GA and at 46% I'm down to 27kw with 46% SOC. I pulled in at 15% and it ran up to 78kw and then quickly tapered way down again.
Roadside says everything looks fine from what they can see. Given that I'm headed to Minneapolis, I'm not sure if it's just a "deal with the slow speeds" or a "Visit a Service Center on the way" kind of problem, but it sure feels really slow to me.
Thoughts?
Thoughts?
