Glad to have Easy Entry with .46 - received Saturday morning right after being dropped off at my home by a Tesla Service Center associate (previously .42).
I like the automatic function whereas before we had our manual Enter/Exit profile.
On entry, I would prefer the steering wheel lower before it projects out. When exiting, I would prefer the steering wheel move up prior to retracting. Or better yet, it should perform both up/in and down/out at the same time. Currently, these functions do not work concurrently. Therefore, I deleted my first settings so there is no more retraction or projection of the steering wheel with Easy Entry; it's now just up and down.
The projection/retraction of the steering wheel allows for more room when getting in and out. Unfortunately with the current iteration of Easy Entry, it doesn't make sense to incorporate this action when you also raise and lower the steering wheel with this feature. Keep it simple with up and down only, unless you're extra patient.
As
@Daniellane mentioned, the seatbelt is an issue depending on your settings. If you have your seat adjust forward when entering, be sure to delay the fastening of your seatbelt. Otherwise, it tends to squeeze you a bit.
No other noticeable changes with AP2. I do miss AP1 in the loaner and being able to change lanes automatically on side roads - not possible in AP2.
Good luck with all your bets.
