SSedan
I know too well they are not maintenance free. But...not all used cars have the same maintenance requirements when purchased is all I was getting at. And not all used cars are sold at a lower price for maintenance reasons.
Buying used cars is always a risk. You need both knowledge and luck. And never believe a clean Car Fax report and never buy version 1.
Tesla just raised the SC charge rate for SR+ from 100 KW to 170KW. I'd prefer it stayed at 100Kw. But I rarely have to go to those anymore and charge daily on a 20 amp outlet at work.
I spoke to Tesla about my car before purchase not Carfax, they said it was regularly serviced. When I paid for the 4 year maintenance they recommended such and it was things like flushing the brake fluid and servicing the AC including desiccant, changing battery coolant. The failures I have seen other than the TPMS module are all pretty common.
On the supercharging rate, they drastically cut the rate on the S 85s and below in 2019 without explaination...........let us see how long the high rates on smaller batteries last.
BUT, not much. As far as I know (having driven Model Ss for 7 years) there simply is not any maintenance. Other than windshield wipers and fluid, I've done nothing. Not even cleaned out the carburetor. Don't know what "repairs" would be required for an S either, unless you're fixing rock dings, and they happen even when new. And since you're saving all that money, you should be able to afford a few MINOR repairs. There isn't even brake maintenance or repair, as it uses regen so much.
I tend to agree that what you'll be looking at is the beautiful curves of an S or the, uh, boxy curves of a Bolt.
I'd like to see a list of all the MAINTENANCE and REPAIRS a $30K S will need as compared to a Bolt.
I gave a list of what I have had to do with mine, though I forget the recalls of the steering bolt and airbag which were vendor issues the airbag one much bigger than Tesla.
My wife has a 2014 Impala with 10-12k more on it than my 2014 P85. The Impala is a better built car, needs fewer and cheaper repairs.
On the brakes, in the climate I live in Tesla is now recommending brake service annually due to binding and corrosion, so they admitted the problem.
On the money saving, I have also documented crudely here that in real winter the vast fuel savings is a myth, other three seasons sure.
Put down the koolaid and be honest.
I paid $50k for the car 2.5 years ago, guessing I could get low $30s for it now. So owning a $30k Tesla is what I am basing my comments on.
In that 2.5 years my range went from 256 (265 miles original) which was awesome to 242 and supercharging speed went from 120kw to 40 though it sounds like once it warms up I might see 70, but in 30f weather after 2 hours on the road it still isn't that fast so might just be summer. This hurts my ability to take trips with this car, my favorite westbound supercharger is 180miles, that stop went from 50minites to probably 1:15-20. 50minutes is a relaxed meal, longer turns into finding a way to kill time.
