It is constantly recording but only for 10 mins at a time which is then over written in a constant loop.
Has the sketch pad in the toybox always been there?
Maybe I didn't notice it before but thought triple tapping the Tesla icon was supposed to open it.
Someone did recommend them.Are they the ones i recommended??
I think the viewer only shows 'saved' clips although you may be on to something with a reformatInstalled the new update, but having issues with the new dash cam viewer. It looks like it is recording fine with the red dot when you start to drive but when I go into the viewer after the drive it does not show the drive I have just done. It shows the older drives before this update fine and strangely if I tap to save a clip it shows the last ten minutes fine. I have taken out the memory stick and it is showing the last drive video on my pc but the viewer is not reading it, any ideas? Do you need to reformat the memory stick?
I have noticed the same behaviour, does not show dashcam footage eventhough it is on the disk.Installed the new update, but having issues with the new dash cam viewer. It looks like it is recording fine with the red dot when you start to drive but when I go into the viewer after the drive it does not show the drive I have just done. It shows the older drives before this update fine and strangely if I tap to save a clip it shows the last ten minutes fine. I have taken out the memory stick and it is showing the last drive video on my pc but the viewer is not reading it, any ideas? Do you need to reformat the memory stick?
Yes, I think you need to book service, but they will probably be able to sort it out remotely if it’s just software that’s causing the problem. Fingers crossed.I installed the update via the app and noticed I got an error saying "Software Update has failed", also got an error trying to turn sentry mode on via the app "Sentry mode has turned off due to a sentry system error". However the car does show that the software is 2020.12.5. I've just traveled into work and the car is telling me to schedule service, most functionality not working like regenerative braking, auto steer. I've just done a full reboot but didn't change anything. Is it really a scheduled service job?
It was the hold both buttons on the steering wheel job, is there another type of reboot? i've not really used the car apart from coming into work today so maybe a couple of cycles will help"Full reboot" I assume was power-off reboot. If not do it.
Hold down both the buttons and hold down the brake pedal, all three until the Tesla logo appears on the screen.It was the hold both buttons on the steering wheel job, is there another type of reboot? i've not really used the car apart from coming into work today so maybe a couple of cycles will help
Same behaviour for me. I only get shown saved recordings.I have noticed the same behaviour, does not show dashcam footage eventhough it is on the disk.
Release notes don't give any clue, do don't know if its by design or a bug.
