My wife drives over 100 miles per day, sometime 150, that is the whole reason I got the tesla, we charge it with our solar. This car was suppose to pay for itself in 5 or 6 years the way my wife drives with the free solar charging. And so that you will have better figures to work with, I will post some long range results for you, so hold on till I post more details. Others are asking for additional information other than the energy app, which I will also provide, this will give you some better figures to work with in your calculations. I also have some more questions if anyone knows -I'm saying you are not observing 100 miles because you didn't actually go that far, but rather extrapolated!
By your own numbers:
Traveling 10 miles used 35 miles, a 3.5x ratio
Traveling 58 miles used 140 miles, a 2.4x ratio
This proves my point! The further you travel the smaller the ratio gets. That suggests that the high consumption is most likely overhead related. That means if you actually travelled 100 miles non-stop, most likely the ratio will reduce further.
As for me posting the energy app, I'm still on 2022.20.7, so I don't have the new energy app that shows how the consumption breaks down. Also I'm in the Bay Area in California and right now peak temperatures is 60-65 degrees, so no way will I blast AC at LO with HI fan speed for 10 miles, as that's just a recipe for getting a cold.
{1}- If you set the temp to LO will this force the single stage compressor to always be engaged regardless of the cabin temperature? (This would be nice to know so others can replicate that are not in so hot climates of 110+ degrees) If the compressor is not on, then the test is meaningless.
{2}- I can hardly believe the 7KW comment from another contributor, I just realized our 4 ton home AC does not even use that much. The "running" wattage (after LRA start) is only 4800 watts, thats my whole house, and the tesla uses 7000 watts? Hard to believe, does anyone know what the running watts are for the tesla air-conditioner? (assuming an ambient temp of 110 degrees) I understand the new 2023 models with the heat pumps are suppose to be extremely efficient for both the AC and the heater.
