Definitely agree with you on legroom and comfort. The Y is absolutely more comfortable for both front and rear passengers than the 3. My short wife wasn't comfortable on long drives even in the back of our Model S because of the low seating and the 3's backseat is even worse.The leg room comment is mind boggling bc the model Y is both longer and much taller. There is a space for your feet under the MY seats that the M3 doesn’t have. I’ve never had anyone tell me they’re unhappy with the legroom in a Y, but go from a Y to a 3, and it feels cramped.
Same. MYP and M3LR/boost.Totally different animals.We have both and feel fortunate to be able to experience both as they are amazing
How was your experience with 21" Ubers on LR? I am contemplating on swapping Geminis to itSame. MYP and M3LR/boost.Totally different animals.
I enjoy driving the 3 much more for handling dynamics and being light on its feet. Ie. Smile every time
I do really like the Y for a more refined drive and comfortable space, visibility, cargo and for family outings/trips.
If I had to choose one, I’d go the MYP. It’s fast, has amazing utility and for an SUV, performs amazing.
Given the thread is about MY LR, LR boost and MYP, I also have some comments about all 3, as I’ve owned a 2021 MYLR and purchased AB after a few months prior to switching into the 22’ MYP:
MYLR - seemed heavy, not much power at higher speeds, decent drive but felt power was missing.
MYLR Boost - much better. Still lacking launch punch but 40kph and up…what a difference!
MYP - not feeling lack of power anywhere at all legal speeds.
Suspension wise, I ran 21” Ubers on the LR as well…so apples to apples…the 22’ MYP seems identical in suspension feel to the 21’ MY LR. Perhaps they refined it somewhat from year to year.![]()
Agree with the first paragraph, but I’ve got a fam to deal with, so the rear legroom is huge, and I’ve noticed that I can put the passenger front seat as far forward as it will go and still sit comfortably, not even relatively. Actually comfortably, which is good.The front legroom in the 3 is greater than the Y, I think, by almost an inch. I also found my leg seemed to be forced inward less (i.e. better angle) with my 3 than my Y. Back seat it is obviously bigger but I ride up front, not in the back. I've had 5 people in my 3 and enough room in the back. Extra room is just wasted space that you pay a penalty for when not needed.
The cargo size difference is a bit misleading. the length and width of the 3/Y are very similar. You just get a higher area where the hatch is. So if I needed to fit something long in my Y, I could likely do it in my 3. This assumes it isn't super tall. I've found I could get remarkably big things in the 3 with just a little more effort than the Y. If the 3 had a hatch like the Y, it'd be very close. As it is, the Y support taller things which may be important for some. Otherwise the 3 is pretty large.
Ever notice how Tesla NEVER compares the volume of the 3 and Y the same? Tesla talks about the volume with the seats folded down in the Y to make it look massively bigger than the 3 and only show the volume of the 3's trunk. If you compare that area from the 3 to the Y (behind the rear seats) the volume is a lot closer than you would think when looking at the total cargo space they quote.
It is an apples-to-oranges comparison just like how they compare acceleration statistics of between the performance models and non-performance. They do it to trick you into thinking there is more of a difference than there really is.
As for range, I'll definitely take my 3 over the Y as it had vastly worse efficiency. Not even close. The Y was even worse than my Model S LR for efficiency. The faster you go, the bigger the difference between the 3 and Y. So if you drive 50-60 mph, the Y may be fairly close to the 3. Drive 75-80 and it is a different story.
Factor in heating and and cooling. That bigger cabin requires more heating and cooling. So on hot/cold days, you'll use more energy to heat/cool it. Physics is at play here. More mass = worse efficiency. More frontal area (with similar drag coefficient) = worse efficiency. So many things work against the Y in these areas; wider, taller, heavier, etc.
Few cars have I regretted buying as much as my Y. It was one of those cars that seemed better on paper than owning it. Knowing what I now know, it was a mistake to buy it. Or at a minimum, I should have bought the MYP. The acceleration of EVs is so smooth, that you don't the rise and fall of the acceleration curve that you do with most ICE cars. So while a 4.5 EV and ICE, may get to 60 in the same time, they typically go about it differently and the ICE car will be at times pulling higher peak G's than typically the EV will. So at times, it will feel quicker than the EV, because it is momentarily and then it will be slower. The other thing I wasn't prepared for was how much the 3/Y die in acceleration after you hit about 50 mph.
Enough info out there for everyone to prioritize what they want and what car will give it to them. Now we have a lot more options. It will be curious to see how the next gen 3 turns out.
They do that a lot (incent with AB) to move them since it basically costs them nothing.In looking over the Tesla Used Vehicle Inventory all of the Long Range Model Y descriptions include a 0 to 60 MPH time of 4.2 seconds. This would imply that AB was already enabled on these used Long Range Model Y vehicles (perhaps as an additional incentive to buy.)
The MYP came out to like $55500 and is eligible for the rebate. The MX is $79000 (80 if I add the white interior, and 82 if I also add the bigger wheels), and slower than the MYP. It does get 45 miles more range per charge though. But for me, that’s NOT worth the 24k difference in price.Congrats on the new car.
Currently, AB only makes sense if you already bought the car and when the delta between the P and LR is at least 5k or more, especially on the MY.
If I had to do it over again with my 3, I'd still go with the LR and add AB even though the price delta is closer than about the 8-9k it was when bought. It is plenty quick with AB, as quick to 60 as the MYP and faster from 40 mph up. WIth the money I saved my investment in MPP coilovers benefitted me more than a little bit quicker 0-60 sprint would.
The MY LR is so slow, even with boost, I'd definitely be going with the MYP over the LR, especially at the small difference in price. If you need the room, the Y makes sense. I'd have to say though with the drop in the X prices, and no eligible for the rebate, I'd really start to think about an MX LR over a MYP.
I can’t simply thumbs up your post bc I’m too new to the forum, but I can confirm the incentive. Or at least that’s what the advisor told me.They do that a lot (incent with AB) to move them since it basically costs them nothing.
I have an MYP and I love taking turns as fast as I can. It's just fun! With my M3LR, I loved seeing how far I could take it. Now that I have an MYP, I'm curious how much it would cost to do some or all of those things you mentioned. I've never been a car person, so I have no clue about the mid-level costs of those kinds of improvements or if it's even worth it. I'm sooooo glad I picked the MYP over the MYLR. I happened to find an inventory car with a discount that made the price delta even smaller and a no brainer to get the MYP. Now I want to have some fun! LOLA solid suspension tune revolving around coilovers, sway bars, camber, toe, traction, trailing arms spehrical bearings removing the sloppy rubber bushings in addition to wheels and tires will make the world of a difference.
I believe it! Tesla cars are way too fun to drive, im def the minority not caring too much about range lol.I have an MYP and I love taking turns as fast as I can. It's just fun! With my M3LR, I loved seeing how far I could take it. Now that I have an MYP, I'm curious how much it would cost to do some or all of those things you mentioned. I've never been a car person, so I have no clue about the mid-level costs of those kinds of improvements or if it's even worth it. I'm sooooo glad I picked the MYP over the MYLR. I happened to find an inventory car with a discount that made the price delta even smaller and a no brainer to get the MYP. Now I want to have some fun! LOL
So that's where it sucks here. I live near the Texas Motor Speedway and they have regular driving events, but the Speedway has decided no electric vehicles are allowed. Our local Tesla group who has guys that want to run the track have been trying for years to explain that EVs are safe, but it's always a "no". There's no track around here that allows EVs. I've actually looked at various classes around here to learn how to properly drive my car on a track and again...having an EV is the problem. I would have to learn on an ICE. You have to drive pretty far to find a track that will allow EVs.I believe it! Tesla cars are way too fun to drive, im def the minority not caring too much about range lol.
Drivability mod cost can get out of hand real quick haha.
What’s more important are your goals with the car, what are some of the drivability impacts you’re experiencing when cornering? Predictability, control, roll, etc. It’s all balance, most folks here prefer a softer ride damping imperfections of the road, while others prefer a sportier feel compromising on those aspects.
My recommendation is join your local autoX club and event, drive your car some what full send in a low danger course. Network with those folks to guide you in your path to tuning your car towards your needs. Once you figure out your purpose you’ll get your car setup in no time.
Welcome to the money pit![]()
