Theres threads in here, search for them. Search comfort suspension.Hi, do you have the part numbers or service ticket I can look at please?
Here you go. Bought and installed a couple of weeks ago on my 2020. It took about ten days for the parts to come in. No issues at all, they were happy to order them.Hi, do you have the part numbers or service ticket I can look at please?
Thanks rich! This works on a performance model? And how much did you pay for parts and labor?Here you go. Bought and installed a couple of weeks ago on my 2020. It took about ten days for the parts to come in. No issues at all, they were happy to order them.
$1124 CAD parts total so not super cheap. Labour was free because DIY. For performance some or all of the parts are different but it’s the same items you need - go check EPC and all the part numbers are there.Thanks rich! This works on a performance model? And how much did you pay for parts and labor?
I've driven just about every suspension kit on the market (OEM and aftermarket) and still feel the MY23 suspension is lacking. Then again, I'm coming from both a ride and performance mindset when looking at improving both comfort and handling. That being said, there's is very little to be gained by installing MY23 components on a 20-22 Model Y when we have clearly much better suspension systems to choose from:
On a Model Y Performance, stepping down from the 21" UberTurbines to 20" with a beefier sidewall coupled with a quality coilover really wakes up and makes the Model YP fun to drive. For those on a budget, the STs are probably the best entry-level coilovers at this time.
- Mountain Pass Performance
- Ohlins R&T
- Redwood Ohlins DFV
- KW Suspensions V3
- ST Suspensions
There might be one torx-headed bolt. Yes I’d say grab a set as they’re cheap and handy anyway. Otherwise you should be good with what you have. Two jacks definitely handy.
You can watch any suspension video to see the process but it’s pretty straightforward. I think I watched Ohlins or something - they explain it well but note you don’t have to worry about the spring compression stuff because the Tesla front unit is preassembled. All very easy really, looking forward to hearing how you get on @bpobill. What year is your car?
Was it for the top of the strut? According to this video the opening on the Y is larger so you don't need the small OD socket like the 3.Aside from sockets and wrenches, the only more specialized tool would be a T50 torx. Although not required, you can get (or make) a small OD 13mm socket for the front shock mounting nuts. With the reduced OD socket, you can remove the shock/spring assembly without having to remove the control arm carrier - big time saver. If you dont need to remove the springs off the front shock, then that's it. Obviously if you do need to remove them, you need a spring compressor.
Lastly, I'd recommend jacking up both sides up in the air before working on one side. Otherwise you'll be fighting the sway bar tension trying to remove the end link.
@bpobill what tires did you change to? 20" wheels?Going from the stock tires to wider and taller was a massive difference. I did that about 3-4 weeks ago and honestly I thought about cancelling my suspension order. I took delivery anyway and since you cant return OTC parts I installed them. After doing the tires I dont feel a massive difference others have described.
I have the 22 MYP still with the 21” Uber and seriously considering the suspension change. While I want to switch out the wheels/tires but holding on that. If I understand your post correctly you are upgrading as well a 22 MYP with the 23 MYP comfort plus suspension?Update:
Just left the mechanic about an hour and a half ago. I am very happy to say that this upgrade is some of the best money I have ever spent. The 2023 comfort suspension upgrade is more than worth it. For a total of $1,382.98, this is a freakin no brainer. Glad that I took this route the second I had the chance to do so.
Differences:
This small upgrade took the car from (in my opinion) from a less than average comfortable ride, to above average. I'd say my car went from feeling like a 2014 civic over potholes and road imperfections, to feeling like a 2022 3 series bimmer. Every f$#$ing time I would go over a bump.. the rattle, the noise, the uncomfort just pissed me off, this upgrade completely took it away. This is the way an MYP should drive.
Here's what I have noticed in my "whole" hour and a half of driving my car back from the mechanic to work. I also went over every pothole, every manhole cap, every road imperfection and the new 23 comfort suspension handles them exactly how I'd like.
- that thump, metalicy squeaky noise, that you get when you go over a pothole, gone. Replaced by a deeper, more quality sounding noise. I don't know how to explain it but the noise is night and day. I used to have random little squeaks and bs. This car also drives much better than the 2022 standard MY I test drove before I bought my 22 MYP.
- rattle, my car used to rattle if I go over most little small imperfections, it's pretty much gone. You go over a bump, and now the car just takes it and goes about that day. I also have a whole set of tennis racquets, my gym bag, random tools, all sorts of stuff that used to make a lot of noise in the trunk, that settled down a whole lot. Very noticable
- comfort, I'd say the ride is about a 50% improvement, so pretty much night and day.
-performance, I couldn't feel any negatives, the car drives much better. On my way to work there is a highway with all sorts of bumps and imperfections, the on ramp is curved and extremely bumpy. I felt much more comfortable and confident driving on it.
I'll update this thread when I get some more insight. As of right now this is a no brainer, if you have a 22MY and under I'd say this is a requirement lol. The car rides WAY BETTER. I would go as far as to say it's a night and day difference. I don't know who the hell online is saying it's not a big difference or it's not worth it.
PS: About the springs.. I forgot to mention you do not need to purchase springs if upgrading from a 22MYP. The mechanic installed them anyways, but he said they were identical. So that would have brought my total cost down to around $1,100.
Correct, I upgraded my 22MYP suspension to 23MYP suspension, not the 23MYLR suspension. This gave me about a 25-35% increase in comfort for less than the cost of a new set of tires, I highly recommend everyone do this with a pre 23MYP.I have the 22 MYP still with the 21” Uber and seriously considering the suspension change. While I want to switch out the wheels/tires but holding on that. If I understand your post correctly you are upgrading as well a 22 MYP with the 23 MYP comfort plus suspension?
What other recommendations do you have now that you have had it for awhile?
Thank you for the input. Have you compared your retrofitted MYP to a new one? Similar?Correct, I upgraded my 22MYP suspension to 23MYP suspension, not the 23MYLR suspension. This gave me about a 25-35% increase in comfort for less than the cost of a new set of tires, I highly recommend everyone do this with a pre 23MYP.
The MYP suspension is MUCH stiffer, and in turn much less comfortable than ANY model year non performance model MY.
