I believe that is a 6-50? From memory.My home has an existing 250v 50a outlet (please see picture)but I’m not finding any adapters to make use of it for model 3 charging. Any suggestions?
Not necessarily easy. A 6-50 does not have a neutral. A 14-50 does have a neutral.It should be easy and about $15 to change to a NEMA 14-50. Just turn off the breaker before you swap.
I agree the right adapter is the best route but I disagree that plugging in an RV would be bad. If the RV is expecting two 120v phases then nothing would happen, just no power. If they never had an RV the it is just a minor inconvenience as all EV charging stations would work on it as the neutral is not used.Not necessarily easy. A 6-50 does not have a neutral. A 14-50 does have a neutral.
Plug an RV into a 14-50 without a neutral and look for bad things to happen.
Buying the correct adapter is the safest solution. And only $20 more plus shipping. But no labor involved.
You are absolutely right for cases when neutral is used by loads. Do you know for sure that UNC uses neutral? it looks like not:No. This is absolutely wrong.
Because of the way “split phase” 120/240v residential service works, if you plugged in an RV then the following would happen:
When you turn on the first 120v device nothing would happen. But then if you turn on a second 120v device on the opposite phase leg then both devices would get power, but if they were not identical load devices one would see over 120v of voltage and one would see less than 120v. This can damage or destroy things or start fires.
Go look up “loose neutral “ and see the bad things that can happen.
Hooking up a 14-50 receptacle with no neutral could be dangerous!
NEMA 14-30 Adapter for Tesla Model S and X Gen 1, 15 ft.
Many EV charging stations have a 6-50 plug.I agree the right adapter is the best route but I disagree that plugging in an RV would be bad. If the RV is expecting two 120v phases then nothing would happen, just no power. If they never had an RV the it is just a minor inconvenience as all EV charging stations would work on it as the neutral is not used.
